AR first reduction gear
Richard Gambrel
05-08-2004 15:28:13
I have a 1951 AR, serial number 275194.
Does the first reduction gear get lubed from the engine, transmission or from its own oil reservoir?
When I drained it, there was only a couple of tablespoons of oil came out.
Thanks,
Richard
Brent
05-11-2004 07:45:44
 Re: AR first reduction gear in reply to Richard Gambrell, 05-08-2004 15:28:13
I have a styled '49 and a '53. They are a little different when it comes to the first reduction cover. The '49 has no "filler" plug and no drain plug and I think it gets its lubrication from the splash from the transmission/rear end. The '53 is similar to the low-seat 60 as it has both the filler and drain plug. My manual for the 60 says to fill the first reduction gear cover with 1-1/2 quarts of the same gear oil used in the transmission/rear end so I can only assume the '53 would be the same. If you look at how everything works, I don't think that engine oil lubricates the 1st reduction gear as there is really no way for the oil to get back into the engine's crankcase. It is time for an fluid change anyways, so drain the oil out of the rear end/transmission, then dump some kerosene into the rear filler plug, if that model has one, and see if it comes out the drain plugs (there are two drain plugs, make sure you remove both as the front one has a bit of a sump that will not drain by only removing the rear plug. I hope this helps.
Brent
Pappy
05-08-2004 16:04:34
The first reduction gear gets its oil from the engine. You should have a pipe plug in the top. Pour a pint of engine oil in the first reduction gear cover to start. Then the gear carries it back up to the engine, and the engine main bearing replenishes the oil.
