50 A Decals
Larry T
05-08-2004 15:25:30
Where is the decal "JOHN DEERE" on the sides suppose to be located. (centered???) Removed old ones and not sure if they where positioned right.
Ralph - Wi
05-09-2004 18:29:48
 Re: 50 A Decals in reply to Larry T, 05-08-2004 15:25:30
I did my '50 two years ago and without going and looking we decided they were centered. My brother's 46 is in the shop now and I think they are forward. I'll check and post back.
Ditto
05-09-2004 19:28:51
 Re: Re: 50 A Decals in reply to Ralph - Wi, 05-09-2004 18:29:48
I typed just exactly the opposite of what I meant to type above. The '46 (slant dash) is approximately centered, - 18" back of the grill on one side, and 13+" on the other side. Correct police would have a real migraine until they found out it had been repainted back in the 60's, along with 0.045 boring and a gas manifold. The mechanic that helps me fit bearing etc (c.a. 50 years experience) and grandson determined that c.a. 2" back of the grill seam was the correct placement for the '50. If that is a problem for the C. P., it is not the only one they will find, but I painted the outside to protect the metal, and went inside to make it run. To be correct the inside of the grill,hood and sides and top of the gas tank can only be painted with over-spray, some of it extremely thin!!!
Pappy
05-08-2004 16:10:46
On the pictures I have, the decal is placed in the center, then, I looked at my operator's manual and two pictures show it centered, and the third picture shows it about 5 inches from the front. Most of the pictures show it centered.
Loren-MN
05-08-2004 18:33:16
 Re: Re: 50 A Decals in reply to Pappy, 05-08-2004 16:10:46
I have the original owner's manual for my 50 A. Pictures in the manual show both locations, but most were of the foward location.
