First Redcution cover removal ?
DPOST
05-08-2004 07:59:01
Hi Gang;
I am tring to pull the ist reduction gear cover on my 45 GM. It's time to ask a question before I break sometihng.
I have the clutch mechanism and belt pully off. I also have removed the tin cover and removed the nut off of the shaft the 1st reduction gear dirves. I have removed all of bolts around it and have the cover loose. It is about a quarter of an inch away form the main case all around. It don't want to come any further. The transmission input shaft seems to be stuck in the bearing on the housing. I have tried some gentle raps on the shaft using a block of wood as a cushon but nothing seems to move.
I have had one of these apart before but it's been over 40 years ago. I dont remember having to do anything special.
Berore I get tough with it and break something, are there any special tricks to getting this apart.
Thanks in advance
D.D.Post
Ralph
05-08-2004 09:10:07
 Re: First Redcution cover removal ? in reply to DPOST, 05-08-2004 07:59:01
I'm not sure I can help, but just went through that with my A. Mine wanted to catch on the dowel pins unless aligned, but I'm guessing yours is hanging on the bearing. The outer race for that bearing is seated in the cover and the inner race is seated on the shaft. I was pounding with what I would call just short of "shatter", when I gave up and drove 80 mi to retrieve my air hammer. With the air hammer it slide into place as if on greased butter.
