12 Volt Fuel Valve (non color question)
Henry J
05-07-2004 15:54:08
I run a powerstroke when I pull the 5th wheel. Keeping Diesel in the tank (and at a decent price) is a challenge.
I am in the planning stages of putting an auxiliary tank in the bed (60 to 100 gal). My consternation is how to lash it up to the main tank. I thought a 12 volt in line fuel valve (about 3/4 inch) in line from the bottom of the tank to the filler neck of the main tank would be the way to go. Hit the switch to add fuel and turn it off when enough has transferred. Time should not be an issue, since I could get some initial flow rates set up on initial transferres.
I am aware of the mega buck systems such as Transfer Flow, but think that I would not live long enough to break even on that way.
I once saw a fundamental system that a guy had set up. He had a manual valve for the transfer, but I am interested in not having to find a place to shut down and wait for the flow.
Any better ideas out there, thoughts, or sources for such a valve.
Thanx
Wayne in Tn.
05-07-2004 17:35:44
 Re: 12 Volt Fuel Valve (non color question) in reply to Henry J, 05-07-2004 15:54:08
Henry J. I once had a 3/4 ton Chevy with two gas tanks. The fuel pump had a return line to the tank to return what fuel was not being burned. There was a 2-way mauual valve in the floorboard. When the left tank got almost empty, you just flipped the lever and the fuel pump would transfer the right tank contents back into the left tank. You could watch the fuel gage start moving back towards full, while driving down the road.
