730 john deere tractor
bill bradley
05-07-2004 15:53:40
why am i getting gas in the base
Mark
05-08-2004 13:12:44
 Re: 730 john deere tractor in reply to bill bradley, 05-07-2004 15:53:40
If it has an automatic fuel shutoff on top of the sediment bowl operated by oil pressure, it could be leaking gas by the diaghram and bleeding back through the oil lines.
Randy V(SD)
05-07-2004 22:58:41
by base do you mean crankcase? if so, your carb needs a new needle and seat on the float. when the tractor is sitting, gas seeps by the needle valve and runs through the intake passages into the cylinders and runs past the rings into the oil in the crankcase. have the carb gone through and your problems will be over. Good luck.
