J.D. 720 Pony Motor Problems
Warren
05-07-2004 14:49:38
FIT, Clooney, and Mel
Hey guys. I just put in a new set of Champion plugs J8C. I ran it at least 15 minutes to get it good and hot. Then I took out 2 plugs while it was still hot. They showed no signs of being wet. I filled the pony tank with fuel and after starting and stopping it a couple of times within (3/4 of an hour) it didn't take long to run that through. I took the pony oil out and put in a new quart. Now, it seems like the fuel is getting back in the oil again. When it was very warm to almost hot I touched the distributor cover and it was very warm. Is this normal or is something else going wrong? When I closed the idle adjusting needle it still keeps running but doesn't stop. When I shut the load screw it doesn't seem to lose any power or slow up any at all. When I turned both the idle adjusting needle and the load screw back to normal position everything stayed about the same. When you open the throttle fast it seems to die out and not want to pick up speed, but if you open the throttle slow it will pick up speed. If I would want to rebuild the carburetor is there a trick to getting it out or do I have to raise the hood up some? One more thing. It doesn't seem to blow out as much black fuel and oil mixed from the exhaust since I did some of the things I explained to you guys.
Clooney
05-07-2004 15:21:25
 Re: J.D. 720 Pony Motor Problems in reply to Warren, 05-07-2004 14:49:38
Warren, you ask...
Quote: �filled the pony tank with fuel and after starting and stopping it a couple of times within (3/4 of an hour) it didn't take long to run that through. I took the pony oil out and put in a new quart. Now, it seems like the fuel is getting back in the oil again�...>>>
_I would pull the oil line from the pony oil pressure controlled fuel shut-off & let it sit for a few hours [then look for fuel coming out of the oil line connection] .. There is a good chance the diaphragm(s) are leaking fuel back into the pony oil through that shut-off & oil supply line...
Quote: �When it was very warm to almost hot I touched the distributor cover and it was very warm. Is this normal or is something else going wrong?��>>> _If the pony was used or run for a while that is normal, also if the diesel was run for a while it would also be normal.. If neither were run for long & you didn�t leave the pony ignition on you might have heated the coils..
Quote: �When I closed the idle adjusting needle it still keeps running but doesn't stop��>>>
_That doesn�t surprise me.. Remember that pony idle screw is really an air adjuster screw so all you did was cut the emulsion air off & make it richer..
Quote: �When I shut the load screw it doesn't seem to lose any power or slow up any at all. When I turned both the idle adjusting needle and the load screw back to normal position everything stayed about the same��>>>
_That isn�t really normal but there is a load channel by-pass for main load fuel & that load adjuster screw only effects the by-pass portion.. I would more believe that you weren�t running it under a load & therefore the carb wasn�t open very far & you were still running on the idle system.. If it was still on the idle system see above for idle fuel control needle.
Quote: �When you open the throttle fast it seems to die out and not want to pick up speed, but if you open the throttle slow it will pick up speed��>>>
_That could either be a piece of dirt [or more than likely a piece of old float] caught in the load orifice in the bottom of the carb.. Or a pinched inside & restricted fuel hose to the carb [somewhat common problem] Try opening or closing the fuel fill door, if that changes it then suspect the fuel hose.. If that is the original fuel hose replace it just to eliminate that.. Or, you have low running voltage at the coils.. Use a voltmeter & check the running voltage at the distributor stud,, if below 4.5-4.75 volts suspect a coil or dash switch resistor mismatch.. If you have new plastic coils then you might need as high as 5 volts to operate them properly.. [you might try a jumper wire from the starter�s battery cable stud to the pony distributor stud [short term or you risk burning out a coil],, if that helps then remove a coil or so from the dash pony coil resistor [back of ign switch]..
_That could be either low power to the coils, or a fuel restriction [see above]..
Quote:� If I would want to rebuild the carburetor is there a trick to getting it out or do I have to raise the hood up some?��>>>
_It isn�t easy but you can get it out through the fuel door access.. I always pull the fuel door right off the tractor to work in there�
Any questions just post back or E-Mail.. I�m sure Frank & Mel will add some more for you to check�
[email protected]
F-I-T
05-07-2004 20:43:34
 Re: Re: J.D. 720 Pony Motor Problems in reply to Clooney, 05-07-2004 15:21:25
There's nothing I can really add to Clooney's super advice, but I can tell you that those old cork floats will put debris in nearly every port and orfice that carb has to offer. On the load screw, on my old '70'D, when I removed the top of the carb, the load jet was snuggly affixed to the end of the needle, so much so that I had to use a bit of heat to separate them. I ran a very SOFT wire through all the passages and then I had very good response to on the adjustment screws.
On the spark, I still maintain and agree that you need to know what the voltage is at the distributor lug. I touched a jumper to mine last year as I was diagnosing my lack of power and high end problem, and as soon as I touched straight battery voltage to it, it smoothed out and ran fine. I eventually had to rig two resistors in parallel until I got a loaded and running voltage of 5V. Haven't had a problem since.
If that oil pressure shut-off is not working right, you need to fix that one first. Otherwise it just continue to ruin the oil. Those diaphragms will not heal themselves!
I would also check and set the timing. since there is no advance of any type, it's pretty simple to do. Set that and you can cross that off the list of possible contributing factors.
Good luck!
Frank
