720 DIESEL HEAD GASKET
SAMMY JOE
05-07-2004 13:00:47
GASKET SET WAS SENT WITH COPPER WASHERS INSTEAD OF LEAD WASHERS. HAD A FAILURE WITHIN A YEAR. ANY TIPS TO INSTALL THE NEW HEAD GASKET SO IT DOES NOT FAIL AGAIN????? INSTRUCTIONS SAY TO INSTALL WITH SMOOTH SIDE DOWN, BUT BOTH SIDES ARE THE SAME APPEARING ON THE GASKET. THANKS FOR YOUR HELP AND STUFF.
Gpower
05-08-2004 09:46:38
 Re: 720 DIESEL HEAD GASKET in reply to SAMMY JOE, 05-07-2004 13:00:47
You should see on your Deere head gasket a lip that is curled over around the cylinder hole, put that lip edge towards the head. You cant just install a head gasket and run it from now on, you will need to retorque the head after you have run the machine up to operating temperature for at least an hour, then let it cool off. Retorque the head and set the valves and you should solve your problem, provided your head and block surface is true and flat. Good luck,
Gpower
buickanddeere
05-07-2004 19:53:25
Everything has to be perfect or that big cast chunk of metal is being twisted by being heated & cooled. It's full of hollow passages filled with air, exhaust, coolant, combustion pressures (thousands of psi) and oil, all of widely different temperatures will leak to somewhere. The head and block mating surfaces have to be flat and square to each other. There can be no cracks. The fasteners/threads cannot be stretched, fatigued, worn or distorted. The surface mating areas have to be ground not too smooth(slippy) or too rough(seepage pathways). The threads should be lubed with high pressure assembly lube and hardened washers used under the nut heads as the cylinder head is likely galled. The fasteners have to be tightened in steps of 20 ft lbs and in the correct sequence with a known good torque wrench. Even with all of this, if the engine is cold and suddenly heavily loaded. She may woof the gasket anyways.
