Help with Removal Of Fan Shaft On 1952 JD B
Charles
05-07-2004 12:25:13
Can anyone explain the easiest way to remove the fan and shaft without loosening governor? I am taking the sheet metal off the tractor anyway to re-piant. I just had the governor re-built and do not want to monkey with it. Is it easier for me to loosen the radiator and slide it forward?.. or is there an easier way (I am draining the system so when we paint the rubber hoses don't get painted). Right now the fan and shaft do not clear the governor enough before it hits the radiator.
The shaft has some oil leakage and in order to repair it and install the proper gaskets it will have to be removed.
Ralph
05-08-2004 09:18:11
 Re: Help with Removal Of Fan Shaft On 1952 JD B in reply to Charles, 05-07-2004 12:25:13
I have only assisted a mechanic in doing this, but don't you have to take the gov off to check proper registry of the gears. The above mechanic does not like to take the radiator off as he claims the retaining bolts with leaky radiators, mud and over flow are prime candidate for twisting off.
Randy V
05-07-2004 22:35:06
You will have to pull the radiator. A the back of the fan shaft is the ventilator pump and there is about 3 sections to it and all of them can leak oil. To take the vent pump apart you have to be able to remove the fan. Also, be careful when you put in the new gaskets because all of the gaskets are also shims for run clearance so make sure that you get the right one. Good luck!
