1951 B Valve lube pipe
Todd
05-06-2004 17:48:14
The '51 B I bought partially assembled has a squeek in the valve area. I took the valve cover off to check the pipe and there are only 2 holes in it - one above both outside valves, and none over the 2 inner valves. Should there be a hole above each valve, or just the 2 outter ones? Thanks.
Will P
05-06-2004 21:11:49
 Re: 1951 B Valve lube pipe in reply to Todd, 05-06-2004 17:48:14
Just like Mike said. Just the 2 outer ones.
People have put holes above the two inner ones, the intakes. She becomes a real oil burner as the oil dripping on the valve stem get sucked into the air intake and gets burned. Don't drill holes.
Will P
Mike M
05-06-2004 19:00:21
Just the two outer ones.
