Duplex carburator adjustment
Tom
05-06-2004 16:35:55
What is the proper way to adjust a duplex carburator on a 70 John Deere??
buickanddeere
05-07-2004 05:29:11
 Re: Duplex carburator adjustment in reply to Tom, 05-06-2004 16:35:55
Setting a carb is like adjusting a oxy-acetylene torch. The rich mixture lights easier but wastes fuel, soots everything up and doesn't produce max output. For a parade and odd jobs tractor in particular the idle and main need to be as lean as possible and still maintain drivability. Some of the smoke and bog from off idle can be caused by puddles/droplets of fuel clinging to manifold and port walls at idle. The sudden rush of air down the ports when the throttle is cracked open will whisk the fuel droplets into the combustion chamber causing a brief over rich puff of smoke. Unless performing prolonged high demand tasks in hot weather. The manifold heat valve needs to be in the hot position. The heat helps keep the fuel in burnable vapour instead of unburnable liquid droplets. The coolant has to be at at least 180F for the engine to begin to operate decent and 195F for proper operation. Otherwise some fuel will tend to stick to "cool" combusiton chamber surfaces instead of being kept in vapour form. Any intake leaks around the manifold to/carb & carb throttle shaft will make setting the mixture near impossible.
Clooney
05-07-2004 04:02:06
Tom, I have to agree with Mel, you need to put a rubber band, or spring on the throttle lever to hold it against the throttle stop, or just hold the throttle lever against the stop with your hand.. That will also mean the base idle stop screw will have to be turned in to raise the base idle back to around 500-600 RPM.. If you don�t do the above the governor could just compensate for the idle screw mixture change & you won�t know if you have the highest idle RPM setting or not..
~As Mel said, short out one side then adjust the other [firing] side for highest idle speed.. Then short out the remaining cylinder [un-short the first side] & adjust the other firing side for highest idle speed.. You will probably find one side slightly higher than the other so try to match the fastest side to the slowest side. You are looking for both sides to produce the exact same power at idle not looking for the smoothest idle on only one cylinder.. When both cylinders are firing again the matched RPM�s side to side will give you the smoothest idle..
~When all done don�t forget to re-set the base idle screw back to about 300 RPM.. Or mark the base idle screw before turning it so you can put it back where it was..
~Before doing the above adjustment be sure to have your manifold heat control set to where you want to operate the tractor & have the tractor up to operating temperature.. It wouldn�t hurt to clean the air cleaner out & put new correct weight oil in it before doing the adjustment either..
~OK now on the load needle? [on the bottom of the float bowl in the center of the nut].. Do the idle needle setting in the above first..
~The load needle should really be set while the tractor is working under a load [like on a Dyno] but you can get it close statically� To do that, either re-set the load screw to somewhere around 2-3 turns out from seated or just start from where it is right now.. The let it idle a short while to stabilize, then briskly push the hand throttle lever to wide open.. If the load screw is set correctly it should take the throttle smoothly without popping, backfiring or surging [a little black smoke puff out of the muffler on throttle up in normal]� If it pops or hesitates on quick throttle up then open the load needle slightly more [� turn more] & try it again.. Keep opening it a little more until it takes a quick throttle up smoothly.. If it puffs black smoke while working you have it too rich.. The above will probably leave the load needle slightly rich but is the best way to get a good throttle response & smooth pulling.. If you are going for max fuel economy on a working tractor then put the tractor under a continuous load & keep turning the load screw in until a slight power degradation is noticed that will give you better fuel economy..
~Any questions just post back or E-Mail..
[email protected]
Roger
05-07-2004 02:59:40
Just a follow-up question. How do you short out that unhooked spark plug wire?
Clooney
05-07-2004 03:21:17
 Re: Re: Duplex carburator adjustment in reply to Roger, 05-07-2004 02:59:40
Roger, don't disconnect the plug wire, just slide an opened paper clip down between the boot & plug wire until the clip is near the metal plug connector metal, then clip a jumper lead from the block or frame to that.. OR, you can pull the plug wire [engine not running] , then bend a wire or paper clip U shaped & slide that up in the plug boot from the plug side then lightly snap the plug wire back on [it probably won�t go all the way back on with that wire in there]..
~You can also do the same thing at the distributor cap by sliding the protective rubber boot up the wire a ways then sliding a paper clip in between the wire & cap tower..
~It makes it easier if you rig both sides up with short wires before starting the tractor..
~In any case, don�t just pull a plug wire off as that high voltage has to go somewhere when the plug wire is pulled off & it can cause arcing in the distributor cap or internal arcing in the ignition coil..
[email protected]
05-06-2004 21:08:47
Your supposed to tie the throttle so the govenor can't open it, short one side and then adjust the other using a tach to get the highest rpm. Then do the same to the other side. Go back and set the faster side to run at the same rpm as the slower side. Thats according to the JD manual anyway.
John T
05-06-2004 18:27:35
Tom, I posted this just a while back somewhere, maybe here or Johnnypopper, but heres how I do mine.
For the bottom 2 idle T screws, similar to the post below, I remove one sides plug wire and short it out, and at slow idle, I adjust the other live still firing side by screwing the idle in just till she leans out, then open it back out just a tad for a sweet slow smooth idle. I dont open them out too far rich where she black smokes. Then short out the side just adjusted and reconnect and adjust the other side the same.
The metereing adjustment (screwdriver slotted brass screw at the bottom of bowls center), I set initially to closed down/in, then back out approx 2 1/2 turns. It should then be set with a good load on the PTO or belt pulley for best results. If it dont black smoke any and is lean under a no load condition, the trouble is thats often too lean if you load her down. i.e. under no load, I would run it a tad on the rich side maybe a bit of black smoke, then under a load she may have enough fuel and do fine.
Good Luck n God Bless, that may not be the official JD recommended way (I have no manual) but it works for me.
John T
Mike
05-06-2004 17:08:53
Do this at idle,Short out one spark plug then adjust the needle on the other side to the best or fastest idle then do the other side
