720 transmisson
pete
05-06-2004 16:08:58
Just got a 720 gas John Deere. My question is where do you check the transmission oil level? I have ordered a service manual but haven't got it yet.
Britt
05-06-2004 18:15:12
 Re: 720 transmisson in reply to pete, 05-06-2004 16:08:58
Pete,
On the left side of the tractor between the flywheel housing and the brake, there is a plug low on the side of the main transmission case. It is just behind gear cover that is partially under the flywheel cover.
Check the color of the oil. If it is milky colored or the level is higher than the check plug, there is probably water in the transmission housing. Under the tractor, there are three very large hex headed drain plugs. The center one is the transmission drain. To just check for water, you can loosen the plug and very carfully back it out. Using a bright light keep watching the threads as you back the plug out. If there is water or oil, it will show up on the threads before the plug comes completely out. If the tractor hasen't been run much lately, the water (if any) will be clear and in the bottom with the oil floating on top. I have seen tractors that have had almost all water with just a little oil on top. It can be very costly if not detected. I Make it a practice to check all the different oil drains for water at least yearly. You can be supprised at how much water can accumulate from condensation in a years time. Check more often if the tractor sits outside (even under a shed). I have even found a lot of water in the engine oil on tractors that have bee sitting outside for a long time.
Good Luck with your 720. They are wonderful tractors.
Britt
