Ideas for Push Blade on Loader
ribbitt
05-06-2004 08:22:35
I have a compact tractor with Woods 5' bucket loader, quick detach bucket mounts. Was thinking it would be nice to have some sort of blade attachment I could use for occasional plowing of snow or light driveway grading. Seems like this would be better than a 3-point hitch mounted blade. Sure would be nice to have some tilt/rotate adjustment, too. Visited the Woods web site, apparently they don't make one. Anybody ever seen anything like this? Dumb idea?
Mark
05-06-2004 16:58:31
 Re: Ideas for Push Blade on Loader in reply to ribbitt, 05-06-2004 08:22:35
For snow on an asphalt drive the blade would be ok. Trying to grade with one would be kinda of unhandy. The blade would be 2-3 ft ahead of the front wheels,and a small lift on the boom would raise the blade 1",then the front tractor wheels would hit the 1" bump,and the blade would go up again,and then you would have to correct this,at the same time the rear wheels would hit the bump,which would put the blade down..... .. Can you say washboard? This is why graders have the blade in the middle.You would be better off with a rear blade for all around grading work.
