6 volt maintenance-free battery??
F-I-T
05-06-2004 07:01:35
Does anyone know if there is such a thing as a 6 volt maintenence free battery? I'd be interested to know.
Thanks!
Frank-in-Pasadena
buickanddeere
05-07-2004 13:37:21
 Re: 6 volt maintenance-free battery?? in reply to F-I-T, 05-06-2004 07:01:35
I wonder what is making these six volters slobber? Charging rates, fill height, plate alloy, internal dimentions getting the electrolyte level too close to the top of the battery even when on the "correct mark"? New battery owners in the area had a batch of droolers. The local dealer's counter man was overfilling the cells on dry charged batteries.
HerbN
05-07-2004 07:07:53
Hey Frank; You got my interest up on this subject. One of our local auto stores has the Optima 6 volt Red Top for a little over $100. Their web site shows the specs. etc. and a suggested retail price around $100. Like to know more about those "Show Car" fake batteries. Hope all is well out west. Herb
Brokenwrench
05-06-2004 17:08:33
You can use an Optima battery,a little higher priced,but if you have a done tractor you won't have to worry about acid leaks ruining the paint. If you are worried about the correct police,they can be hidden in one of the reproduction old time dummy battery cases they sell for the car restoration crowd. These cases look authentic,right down to the lead tie straps on top.
F-I-T
05-06-2004 17:15:07
 Re: Re: 6 volt maintenance-free battery?? in reply to Brokenwrench, 05-06-2004 17:08:33
BW:
Where would I find a false battery case like that? Now I'm getting interested.....
F-I-T
Bob
05-06-2004 09:44:13
Optima makes one. Spendy, but good....
Henry J
05-06-2004 08:28:07
Frank
My 6 volter has the dribbling blues also. It sure eats up things below it.
I was thinking that when I get around to putting the battery and box in mine again, I was gonna look for one of the plastic battery boxes and cut the sides down if they are taller than the battery. Too bad there is not near enough room to also put the plastic top on it.
If a correct policeman gets caught with his head inside my battery door, I should get a free kick at his rear lol.
F-I-T
05-06-2004 09:16:15
 Re: Re: 6 volt maintenance-free battery?? in reply to Henry J, 05-06-2004 08:28:07
Henry:
If you find a good place to find those plastic boxes for a Group 1 6 volter, let me know. I can only find the larger ones, and they won't fit in the cubby hole.
As far as the Correct Police, I can honestly say I've never had a prblem with them. If anyone asks me a question, I try my best to answer. If they TELL me about my tractor, I tell them it was mine when you walked up and it'll be mine when you leave. They don't hang around for very long. Must be my deodorant
Frank
Henry J
05-06-2004 13:15:00
 Re: Re: Re: 6 volt maintenance-free battery?? in reply to F-I-T, 05-06-2004 09:16:15
Frank
It will be a while before I get serious looking. If I find one you will be the first to know.
My grand daddy always said, "just shows you, a blind hog can always find an acorn" - hope he is correct in this case.
John T
05-06-2004 07:27:55
Yo Frank Are you the one and original F I T ?? I though he was in Talahassee, he e mailed me and I was gonna stop buy when Im in Florida. He has his own web site, That you ol buddy???
Anyway, I did a search on Google for 6 Volt Maintenance Free Battery, and came up with a gazillion links lol. Yeppers they sure make 6 volt maintenance free in all sorts n sizes n ratings as one might expect HOWEVER, they appeared as a specialty item and many were wayyyyy yy expensive. Also, I found way more light duty ones than autmotove types.
Im thinking you probably mean one of those new (or even the older type) 6 volt maintenance free same as the 12 volt units appearing on shelves about anywhere. Personally I HAVE NOT SEEN ANY 6 VOLT UNITS ON SHELVES EITHER. The web search indicates they do indeeed make them, but you may have a hard time findig one at Wally World.
The newer batteries have good CCA and amp/hr ratings and maintenance free would be a nice thing, but I doubt if I would pay 2 or 3 times the price just to avoid a lil routine and rare maintenance myself. If one buys a good heavy duty regular battery, uses 00 Gauge Cables, has a good engine n starter motor, maintains the charging system for proper charge rate, maybe even put the battery in one of those marine battery plastic protective boxes, uses felt washers under the terminals plus sprays them with battery protectant, theres not all that much maintenance for years of trouble free operation actually.
Best wishes n God Bless ya Frank, regardless which Frank you may be.
John T
F-I-T
05-06-2004 07:36:23
 Re: Re: 6 volt maintenance-free battery?? in reply to John T, 05-06-2004 07:27:55
Thanks John.
Yes, it's me. I'm working in Pasadena, so sometimes I sign off as F-I-P.
I want to try a maintenance-free in my VAC Case. It tends to dribble from the caps of the battery in it now, and since it's near an end, I'd like to try a sealed unit.
Any idea when you might be heading through FLA? I was on the Ohio/Indiana border visiting my Mom last weekend, so I was near your neck of the woods.
Frank-in-Tallahassee
Mike M
05-06-2004 08:15:42
 Re: Re: Re: 6 volt maintenance-free battery?? in reply to F-I-T, 05-06-2004 07:36:23
I know what you mean about those dribbling batteries. Once in a while you get one thats made right and doesn't leak. You might want to check into those Optima batteries,gel cell and I think they come in 6 volt.
HerbN
05-07-2004 07:12:48
 Re: Re: Re: Re: 6 volt maintenance-free battery?? in reply to Mike M, 05-06-2004 08:15:42
Hey Frank; You got my interest up on this subject. One of my local auto parts dealers sells the Optima Red Top 6 volt for a little over $100. The Optima web site shows the suggested retail to be around $100 and lists all the specs. Would like to know more about those show car blanks which might be used to cove one up. Hope all is well out west. Herb
F-I-T
05-07-2004 07:19:38
 Re: Re: Re: Re: Re: 6 volt maintenance-free batter in reply to HerbN, 05-07-2004 07:12:48
Herb:
I'm always surprised at how much interest there can be on these simple topics. Seems like everytime we deal with a little thing like keeping batteries from drooling on our new tractor paint, there are probably hundreds of folks out there fighting the same situation.
Frank
