4520 4620 4630
wynnthrop kittl
05-06-2004 06:00:53
Hello Everyone! I am considering buying one of the big Deeres and I'm getting conflicting advise. Excluding the soundgard cab and tin wear is there any difference between between the 4520--4620--4630 models? I have not been around much Green paint, but all Deere owners just seem so satisfied that it seems the logical next step. Thanks much for your input,
Wynn
charles
05-06-2004 09:28:15
 Re: 4520 4620 4630 in reply to wynnthrop kittlebottom, 05-06-2004 06:00:53
The 4430 has the 2 speed pto and turbo ,125+ hp .same as 4630 but no intercooler
Ryan
05-06-2004 07:35:29
I believe the 4630 was 1000 pto shaft only....I believe this is corret, if someone knows otherwise please say so.
Ryan
Ellis
05-06-2004 07:18:43
We have a 4620 and a 4440 and both tractors are excellent. When you get into a 30/40 series tractor the comfort and convenvience are far superior. The sound gaurd cabs are very well insulated and quiet in comparison to the cabs that were installed on the 20 series. The 30/40 series have a quad range tranny that gives a wider selection of ground speeds with a no clutch shift in each range in comparison to the old syncro shift unless you end up with a power shift tranny. As an end resultant you will be paying more for comfort conveience and a higher technology. They are all great tractors, we would never get rid of ours. Hope you enjoy your purchase. Ellis
JDBert
05-06-2004 06:32:59
The 4520 had a tuboed 404, but also had the injection pump (a rotary rosa master) that was mounted on the right REAR of the motor. When they went to the 4620 the 404 was turboed and the pump was moved to the right Front of the motor and changed to a inline bosch pump. Both tractors where built like trains especially in the rear, and both were available with the 8 speed power shift or the syncro. Other then the motor they both are basically the same.
The 4630 is a different tractor, motor is the same as the 4620 with the exception of the updated aftercooler (instead of top and bottome halves deere went to left and right halves). The rear end is built a little lighter as is the whole tractor. All three are good reliable tractors our 4630 was turning 180/hp and we never had trouble with it except the 2 speed clutch pack on the quad tranny went out. Our 4620 turns 165 and is a good horse as well, have to make sure that the radiators are clean though other wise they like to creep up to that 200 degree range easily.
thurlow
05-06-2004 08:50:51
 Re: Re: 4520 4620 4630 in reply to JDBert, 05-06-2004 06:32:59
This is based strictly on my quite fallible memory..... concerning the rear ends; we had two 4620s in the '70s--'80s; tore the rear end out of one; the replacement parts were "seriously" stronger; don't think Deere did a recall, but if the tractors don't have the 'up-grade', I'd be a little leary; also had a black-stripe 1066 at the same time; same factory HP (135); we had to practically beg someone to drive it; everyone want to run one of the 46s..... ....
Fred G
05-06-2004 06:16:10
I'm not an expert but I can share what I have learned here at YTMag. The 4520 had a few engine issues I believe due to the non-intercooled turbo...Deere's first try at a turbo as I recall. The 4620 improved on this design so it would be viewed as the more desireable of the two. (Although many people here have 4520's with upgrades and are happy with them.)
The 4630 is a different animal entirely. The soundgard cab is much quieter. I grew up with a 4230 and it was a great tractor to operate with better controls and features. I'm pretty sure you could get a 16-speed quad-range on this tractor too along with the syncro-range and 8 speed power shift like the 20 series. The only "bad" thing I have read is that the 404 motor in the 4630 is pretty high-strung at the 150HP level, that is, low-end torque is not the best and you're pushing the motor pretty hard.
If price were no object the pecking order would probably be 4630, 4620, 4520. My guess is the 4630 will be priced quite a bit higher than either 20 series tractor.
There are others here with a lot more knowledge then me.....
