4020 hydraulic pump noise
Todd Wiscal
05-05-2004 23:55:45
my '68 4020 has a noisy hydraulic pump. recent purchase with no history. pump appears to have been replaced at some point. noise sounds sort of like excessive valvetrain noise in an engine. i removed the coupler and examined the bushings and coupler, don't think the noise is coming from there. turned the pump by hand and shaft seems to be tight. pump turned several degrees very hard, then loosened slightly for a several degrees, varying like this for complete rotation. is there a method to determine where this noise is coming from? hydraulics all seem to work fine. thanks in advance.
Todd Wiscal
05-06-2004 14:02:50
 Re: 4020 hydraulic pump noise in reply to Todd Wiscal, 05-05-2004 23:55:45
thanks guys.
- no i didn't remove the pump shaft coupler, will check that first.
-i'm sure the noise is coming from the hyd pump
-if coupler is ok, i'll check out stroke control valve and pistons
thanks again
todd
jdemaris
05-06-2004 05:59:51
The hydraulic stroke-control valve is a common wear item in the pump. When it gets worn, it will hammer like crazy and usually make the tractor start/crank hard. If it's worn, the noise gets the worst when no hydraulic functions are being used, and almost goes away when they ARE being used. It will make as much noise as a bad drive coupler. If you have an el-cheapo manual destroker installed - just destroke the pump and see if it gets quiet. If not, buy one for $5. If you determine that #1 the stroke-control valve is not bad, and #2 you are sure the entire external pump drive is good - and tight (including the four rubber bushings and also the take down 3/8" bolts are tight where the split-splined coupler gets tightened onto the pump shaft - then it will behoove you to pull out a piston or two for examination. You can't get to all of them with the pump installed - so just pull one or two. If the springs look good and the pistons are not badly scored, then the pump internals are probably okay. All it takes is one metal component to fail and it will usually trash all the pistons. So, even looking at one is a good indicator. You might notice that the big hex-plugs that hold the pistons and springs in have teflon sheaves on them over the o-rings. That was a Deere update back in the early 70s. They had some trouble with the o-rings getting cut when tightening the caps and thus added the teflon.
Mike M
05-06-2004 05:52:58
That is the nature of the beast,some are real noisy some are not so bad. I would examine the splines,put in a new pump side coupler if it would not tighten on the splines and I would put in new rubber bushings for sure. I would also check the presure,but if all works fine thats all that matters.P.S. did you run it with it unhooked to make sure it wasn't valve train noise ? If you just bought it I would go ahead and adjust the valves too.
david val
05-06-2004 05:39:47
did you completely remove the coupler and checked the splines?
david
