JD 3010 gas PTO problem
Brad A.
05-05-2004 21:16:22
I bought a 3010 gas and it runs pretty good. I got a little over anxious and hooked up to my JD brush mower and it mowed like a dream, until I grounded out the mower once and that was it. A terrible rattle from the PTO started and the shaft doesn't turn. Disconnected, the shaft turns like it should with no noise. The JD dealer here said there is a shear pin on the PTO shaft that may have busted. The Manuals say I need to split the tractor to fix. Question is, is that necessary "if" it is only a shear pin?
Brokenwrench
05-06-2004 04:19:25
 Re: JD 3010 gas PTO problem in reply to Brad A., 05-05-2004 21:16:22
It is not a shear pin,it is a pin that engages the 540 gear train that bends and doesn't allow the 540 to engage entirely.Here's a cheap trick to get you some more time out of it before you fix it right. Remove the 4 bolts that hold the 540 shaft,remove the shaft,put a penny under the shaft in the center,and bolt it back up tight.Make sure you keep those bolts tight,use some Locktite or safety wire them.Some times this quick fix will last for years if the pin isn't bent severely.All it does is push the engagement rod farther in to help engage the gear train.
Brad A.
05-06-2004 15:14:30
 Re: Re: JD 3010 gas PTO problem in reply to Brokenwrench, 05-06-2004 04:19:25
Thanks, I will give that a try.
Brad
