Poor Boy, you ask... Quote: "I'm going to rebuild carb on 620 , how do you remove the steel balls to clean out the passages"...>>> --Answ, very carefully.. First, are you sure they have to come out? Those little devils come out with great difficulty & the carb is easy to damage while doing so.. ~If it doesn't have an idle problem you might not have to remove them.. If you do have an idle problem then sometimes you can repair that by just removing the throttle plates & working a fine [soft] wire through the idle orifices with a long pair of needle nose pliers. ~If your carb is bad enough that they have to come out there are a few ways of doing that.. ~The first is to tack weld little tails on the balls & pull them with a pair of side cutters [I haven�t done them that way in a long while now].. ~The second is to drill them out. That is an easy way to damage the ball bores if done by hand.. If you do them that way be sure to use a transfer punch to put a nice centered punch mark in the center of the ball top or you will surly drill off center .. ~The way I have been using lately is to set the carb up in my mill & use a perfectly centered Cobalt cutter to mill those pesky little balls out.. That seems to work the best & allows the cutter to stay perfectly centered on those balls.. ~If you pull those balls you will need new ones, or you can use short set screws.. Roberts Carb has new balls for sale.. [email protected]
