BB, to answer your question ... Quote: "Does anyone have a set of steps to go through in order to tune the regulator? or did I mess up monkeying with it?"...>>> --Answ, I do have a procedure I wrote for a 2- cylinder Deere a while back.. It is a long procedure & requires some additional equipment to properly make the settings.. Those current/voltage regulators are more complex that they look.. If you want to try that adjustment give me an E-Mail & put �VOLTAGE REGULATOR� in big letters in the subject line so I can find it [I�m buried in E-Mails at the moment].. I will then send you the procedure for adjusting & properly setting your regulator.. ~If you are in a hurry you might just install a new regulator.. ~You might also want to give your charging system a quick test top see if it�s hooked up correctly & has proper power to the regulator� SEE BELOW--- **Before doing the below, make sure your battery is installed correctly [your tractor came as positive ground].. That means the battery�s positive post should be connected to the tractor chassis..** ** Then verify the generator/regulator is wired correctly�The [Fld] on the regulator connects to the [F] on the generator,, the [GEN] on the regulator connects to the [A] on the generator,, the [BAT] on the regulator connects to the hot wire coming from the ammeter,, if your regulator has an [L] terminal it connects to the ignition switch�s [bat] terminal� If your regulator has an [L] terminal & you have the [battery wire from the ammeter] & ignition switch�s [bat] wire hooked to the wrong regulator terminals it will act real strange & try to charge but won�t operate correctly, so check that first.. ~First thing to do is verify the ammeter is working properly,,, to do that simply turn the lights on with the engine not running, if you show a discharge your ammeter is probably working.. [if it reads backwards then either the battery or ammeter is wired backwards]
~Second,,, [if your ammeter is working in the above] make sure you have battery voltage at the [BAT] terminal on the voltage regulator [the battery terminal is the one with the bigger wire that doesn't go to the generator. If you don't have battery power at the regulator's [Bat] terminal post back. [If I put all the trouble shooting here it will get real confusing- FAST] ~Third,,, MAKE SURE you have a good clean ground connection on the generator,, regulator,, & the generator belt isn't loose or slipping. ~Forth,,, polarize the generator,, To do that, just ground the generator�s [F] post {smaller of the two}, then momentarily run a jumper wire from the regulators battery [Bat] terminal to the generators [A] post {larger of the two}.. You should see a small spark & if so it's polarized. Now try the tractor to see if the generator charges,, if not go to #5. ~Fifth,,,[If you have battery voltage at the regulator, & good grounds], then just start the tractor & run at fast idle, then use a jumper wire & short the [F] post {smaller of the two} on the generator to the generator's case,,, If it charges then you have a bad regulator, open in the wire from generators [F] post to the regulators [Fld] terminal or a bad regulator ground. ~Sixth,,, If it still doesn't charge, leave the [F] post grounded & use a jumper wire & jump the [A] post on the generator to the [Bat] terminal on the regulator,,, if it charges then you have a bad regulator, or open in the wire from the generator's [A] post to the regulator's [Gen] terminal]. ~Seventh,,, if it still doesn't charge you can do a generator motoring test.. To do that just remove both wires connected to the generator & remove the generator belt,, Then re-ground the [F] post to the generator frame, then run battery power from the regulator's [Bat] terminal to the generators [A] post, the generator should start to motor, then REMOVE the ground wire from the [F] post, the generator should speed up, if so the generator is probably good. If the generator doesn't pass the motoring test post back for directions on repairing the generator or take it back to the rebuilder..
~It helps to print this test sheet out & take it out to the tractor while working on it.. I purposely tried to keep this post short so it prints easily it ended up longer that I wanted. [email protected]
