4010 Drive Shaft / PTO Shaft Vertical Play
Kenny G.
05-05-2004 18:12:01
I have my 4010 split to replace the clutches and release bearings and noticed what seems like quite a bit of vertical movement on the ends of the two shafts (maybe 3/4" from center). I was wondering if the clutch shaft roller bearing and transmission drive shaft should hold them tighter or do the clutch operating sleeve assembly and operating forks keep them in place or do I probably have a junk clutch shaft roller bearing (at least). I'd really appreciate some expert advice since I don't want to split the tractor unnecessarily but don't want to have to do it again after it's together and painted either. Thanks in advance.
