Warren: >>I took a (hot and cold) compression test. Hot was 120 (all cylinders) didn't vary 1lb. either way. Cold was 110 (all cylinders) didn't vary 1lb. either way. Which I thought was pretty good. I think that is pretty good as well. Sounds like you don�t have an issue with rings and valves. >>It runs good but now we have gas getting into the oil and in the cylinders because the plugs are really wet. This has either a bad needle and seat, a bad float, and/or a bad fuel shut-off. If it were mine, I�d take the carb off and replace the needle and seat (the Deere kit for this with gaskets was $13 last one I bought). Then I would repair the oil-pressure fuel shut-off so it works correctly. Probably needs a diaphragm. >>It just barely keeps running because it gets to much fuel. Because when I took the plugs out you could see splashes of little gas and oil when turned over it pushes it out the plug holes. I think you might have an ignition problem. Fouling and slow running is a symptom of a pony with low spark voltage. As a trial, check to see what the running voltage at the distributor lug is. You need at least 4.75V running. If you have the newer after-market coils, they like a bit more�I run mine right at 5V and they fire great. If the voltage is low, take a jumper and come from the starter cable to the distributor lug. This will supply straight battery voltage to the distributor, then higher primary voltage will make for a higher secondary voltage, and it should run much better if the carb problems have been addressed. Don't let it run this way for very long, though, as you don't want to burn out the coils. Then again, it might just need four new spark plugs (J8C's). >>When it is running it pushes out the muffler pipe of the pony motor. You can see quick black polka dots of gas and oil if a piece of cloth would be held under for a split second. As soon as you get it firing hot, I�m betting that stuff will burn up and be gone. >>Also, when I opened the pony motor hatch door the fuel shut off valve was leaking fuel into the oil, but how is this fuel getting into the oil system? Well, the oil line from the pony is allowing the fuel which is leaking past the diaphragm and back down the line into oiul sump. Or, the fuel is over filling the carb bowl, leaking past the needle and into the manifold, past the rings, and into the sump. When I pull the pony oil dip stick you can smell the gas mixed with the oil. >>Use a turkey baster and get most of the oil out, then refill. Pony rods don�t much like their aluminum bearing surfaces wrung against a steel crank journal using gasoline as a lubricant. Frank-in-Tallahassee
