Leakage From 1952 JD B Fan Shaft
Charles
05-05-2004 11:59:23
The pump flange on the fan shaft leaked oil, so I loosened the bolts lightly filed the flange and spread gasket maker and re-tightened the bolts. After about 10 minutes use of the tractor, oil started leaking out of the flange and also pushing out the seal on the fan end of the shaft (I just had the fan repacked professionally).
It struck me that maybe I clogged something and caused a oil pressure build up, which in turn caused the oil to break through the gasket maker and the fan seal??? Does this sound probable? And besides cleaning the clogged holes, etc. do I need to re-seal the fan shaft or is it possible it only leaked due to oil pressure?
