2555 john deere hydraulic pressure specs.
gerard
05-04-2004 21:09:16
Need info on what psi on output of transmission pump whil idling?
Ways to test for low pressure or leaks in system between the trans pump, trans cover priority valve? Note: No air found iin discharge of trans pump while testing at trans cover. Can any leaks be in back half of trans case that can cause pressure loss?
Any contacts by web for factory help?
david val
05-05-2004 11:11:07
 Re: 2555 john deere hydraulic pressure specs. in reply to gerard, 05-04-2004 21:09:16
pressure is measured at the front plug on the right side of the shift cover. pressure should be about 150 psi, but most important, it should be almost the same at low idle. if the pressure drops st low idle (say below 130 to 140 psi), then there is probably a leak in the system. read the pressure with pto on and off and hi-lo at high and low. if the pressure is dropped in one of these conditions and is ok at others, then the leak is at that circuit. if the pressure drop is in all these conditions, then the leak is 'general'. first thing to check is the oil filter relief valve that tends to get stuck by a broken rollpin due to plugged filter. if this valve is ok, then there is probably a broken tube inside the transmission.
david
Gerard
06-04-2004 20:40:16
 Re: Re: 2555 john deere hydraulic pressure specs. in reply to david val, 05-05-2004 11:11:07
Thanks for the help David, it was a broken discharge tube from the transmission pump in the case.
