80 transmission question (pony and main!)
Brandon
05-04-2004 19:50:13
I have some questions about the transmissions on my 80. I currently have the pony in MANY pieces, and the main transmission cover off, as well!
Pony transmission...I've noticed while playing with it, when I engage the trans, then let it back out that the clutch throwout bearing usually doesn't release unless I give it a little pressure by hand, and it snaps back. I was thinking this is normal (because the springs on the flywheel would do this when installed), but can someone tell me for sure?! This seems similar to the problem we had when running it. I would start the pony, and try to engage to the diesel. If it didn't engage (grinding!) I would have to shut the pony off to make the pinion stop...
Main tractor transmission...I took the gear shifter cover off. The only real problem was that it does NOT like to come out of first gear. I don't really see anything obviously wrong in the shifters, or gummed up, any suggestions. Please?
Some pictures:
Inside transmission
Link
Shifters
Link
Gearshift
Link
Thanks all!
Brandon
Soldier Tom
05-06-2004 05:41:44
 Re: 80 transmission question (pony and main!) in reply to Brandon, 05-04-2004 19:50:13
My 720 pony did the same thing. I would have to hold a little pressure back on it to stop it from spinning. Way I did it for a while was to engage the gear from the transmission to the flywheel, but not the clutch, then once the pony got up to speed, I'd go on and pull that last quarter inch or so and put the spin to the flywheel. That worked well enough, but it took my left hand to hold the transmission lever back, right hand to run the pony choke/throttle, and my left foot to push the ignition button for the pony. Do you get a mental picture of it all? It was a sight to see! Do yourself the favor of replacing the brake, and ENJOY it a bit more. ~Walk in peace~
robert
05-05-2004 04:45:38
there is a transmission brake pad .Yours is probably shot.look at a parts pic.set up clutch properly also,see that disc splines clean and free on shaft.don't know on 1st gear.
