30 series LP distributors
pete
01-26-2004 16:20:08
Is there a differance between the 30 series LP engine distributor and the 30 series gas engine distributors?
70 plowboy
01-27-2004 04:24:28
 Re: 30 series LP distributors in reply to pete, 01-26-2004 16:20:08
it will bolt in! but it doesnt have as much of a advance curve, youd be better off useing the gassers unless you do have a lp!! If you have one sitting there that is in better shape than the gas one!! You could posably change the advance over and use the lp one OTHER wise they should be the same
Jim in AK
01-26-2004 23:20:08
Pete,
I have two trucks that burn LP & I have converted several others. The only differance is in the timing of the distributor not the distributor itself.
Jim in AK
twopop
01-26-2004 19:35:47
dont know for sure,but,i would suspect there is a differance in the centifical advance mechanism.lpg does not require as much advance as gasoline does.for instance,a 350 farmall has 22 degrees advance at full throttle on gasoline whereas an lp only has 16 degrees advance
Clooney
01-26-2004 17:02:11
Pete, not that I know of but I don't work on many LP tractors so maybe an LP person can add something for you here.. There wouldn't be much of a reason to have different distributors as both the 30 series gas & LP distributors already turn at 1/2 engine speed..
[email protected]
