D Oil Leak
Bill
05-04-2004 19:13:48
Clooney,
The oil leak I have on my styled D is out of one of two cover plates behind the flywheel toward the lower area of flywheel. It appears to be a gasket of some sort. How is the best way to remove the flywheel and is there a special tools or puller to do this job? How much does the flywheel weigh? I hope you or any other readers can help me. Thank you.
Mark
05-05-2004 07:20:30
 Re: D Oil Leak in reply to Bill, 05-04-2004 19:13:48
Be sure to replace that cork seal along with he gasket.
Clooney
05-05-2004 03:27:29
Bill, Marty pretty well covered it.. I haven't ever weighed the late D flywheel but it is well over a hundred pounds [I have pulled those by hand but wouldn't suggest that as a safe way]..
~Before pulling that flywheel make sure the >< marks on the flywheel & crankshaft are visible & match.. If not, make your own marks to re-align the flywheel to crankshaft when re-assembling..
~Almost any puller that will bolt to the flywheel holes & has a center stud or bolt will work. It usually doesn't take much pulling to remove those flywheels but just pulling by hand isn't usually enough either..
~I�m not a big believer in driving a wedge into the flywheel slot to loosen the flywheel but have done it on occasion [try without doing that first]..
~To get that flywheel off I usually use a couple of different ways depending on where I am & what�s available.. The first is to put a large old fan belt or cable through one of the flywheel holes then use a chain fall or come-along from a high point in the shop to hold the flywheel at crank height while I slide it off the crankshaft�. The other well used way is to use a floor jack with the saddle padded with a couple of shop towels to protect the flywheel then slide the flywheel out on the floor jack, then lower it.. I usually do the jack thing by myself but 2 people make it much safer.. If doing outside away from the shop I just use the belt/cable thing but use a front end loader to attach to..
~When re-installing the flywheel just slide the flywheel on until you have .005�-.010� crankshaft end play then lightly tighten the flywheel bolts, then re-check the end play & if still ok fully tighten the flywheel bolts.. You will need to hold the R/H side of the crankshaft over to the left with a block of wood or small bottle jack between the R/H tire & pulley cover [engage the clutch first]..
[email protected]
Marty Z
05-04-2004 23:17:49
Fly wheel on my 35 "D" was 123 lbs. I made a puller out of threaded rod and a piece of channel iron. It wasn't prety but it worked. Also had to pound a couple of chisels in the crack of the fly wheel right near the shaft of the crank.
Marty Z
