38 b timing motor crank
lynn daniels
05-04-2004 19:05:52
38 b can't find any timing marks on motor crank to time it. Does anybody know where to set it to time?
Clooney
05-05-2004 03:29:53
 Re: 38 b timing motor crank in reply to lynn daniels, 05-04-2004 19:05:52
Lynn, are you trying to time the crankshaft to the camshaft or trying to time the magneto/distributor to the crankshaft position?
[email protected]
Lynn
05-05-2004 05:12:11
 Re: Re: 38 b timing motor crank in reply to Clooney, 05-05-2004 03:29:53
I am trying to time the crankshaft to the camshaft
Clooney
05-05-2004 07:14:14
 Re: Re: Re: 38 b timing motor crank in reply to Lynn, 05-05-2004 05:12:11
Lynn, the crankshaft timing mark should be on the inside of the crank timing gear & be viewable by looking through the open crankcase cover area.. If the gear is pitted or rusty it will hard to find or might be obliterated.
~If you can�t find the mark on the gear then install the flywheel on the crankshaft so the flywheel to crank marks line up, then turn the flywheel until the �L/H ex open� on the flywheel lines up with the case mark [behind the flywheel & even in height with the center of the crankshaft],, then time the cam so the L/H exhaust lobe is just starting to move the follower.. Then either install the cyl. head or use a long stiff wire or rod to reach the L/H exhaust cam follower & place a dial indicator on the L/H follower.. When the cam is timed correctly the L/H exhaust valve should just start to open �0� lash [cyl head on & valves adjusted to .020�] or the L/H ex follower should move about .020� [cyl head off the tractor] when the �L/H ex open� lines up with [or is within about 1� of] the case mark..
[email protected]
