12 VOLT SYSTEM
GALEN EINSPAHR
05-04-2004 18:56:07
MY 4010 12 VOLT SYSTEM WHY DID THEY CONVERT SO MANY OF THEM FROM 24 VOLTS
Bob
05-04-2004 21:29:15
 Re: 12 VOLT SYSTEM in reply to GALEN EINSPAHR, 05-04-2004 18:56:07
Ignorance, and lack of people who understood how to troubleshoot the system.
RussR
05-05-2004 17:12:38
 Re: Re: 12 VOLT SYSTEM in reply to Bob, 05-04-2004 21:29:15
JD 24Volt System; It was a perfect design until it went into the tractor prototype. Then there was plenty of doubt in the real world of engine starting and crops to plant and harvest. They (JD) must have forgot all those 24v rigs had to be practical and reliable. Oh well. Needed a 24volt system recharging computer in the shed complete with heavy duty automatic isolation switches.
This would allow for two balanced 12volt battery charging cycles. The owner or hired hand could then be concerned with all the other daily routines and challenges. Not will the fully isolated 24volt starter get enuf zap the next time to make a daily profit. Well so much for the fantasy farmer fairytale. Do whatever it takes to restart the big rig.
MIKE HANLEY
05-04-2004 20:40:20
Without out getting into the high tect words,,,,,it's,,,, Because the 24 volt system was and is a goofy system where the 24 volt system was really two 12 volt systems that had an internal ground. Because the system was really two 12 volt systems, to get the 24 volts the two 12 volt systems had to be in balance. They were known to get the batteries out of balance and then when called on for the 24 volts for starting,,,,,it just wasn't there with thw full 24 Volts. To bring the two systems back into balance with one battery charger was a long haul as one 12volt system was "N" ground and the other half of the system was "P" ground. And with the internal ground of the starter, any nick in that part of the wiring could and has caused the whole system to fry. We have both our 720 diesels converted from the 24 volt system to 12 volt "N" ground. Now in the winter I don't have to worry if the system is in balance to put out the 24volts. I just hit the botton aqnd the 12 volt is ready to go. If the batteries do get down, I can charge the batteries just as easy as on a 12 volt gas tractor
Bob
05-04-2004 21:31:43
 Re: Re: 12 VOLT SYSTEM in reply to MIKE HANLEY, 05-04-2004 20:40:20
Mike,
Conventional starters have an internal ground.
The Deere 24 Volt starters have NO INTERNAL GROUND.
As a matter of fact, all the guts in a Deere 24 Volt starter are insulated (isolated) completely from the metal frame of the starter.
MIKE HANLEY
05-04-2004 23:29:34
 Re: Re: Re: 12 VOLT SYSTEM in reply to Bob, 05-04-2004 21:31:43
I should have picked better wording on the grounding. When converting a 24 volt starter to 12 volts the ground instead of returning to the batteries and insulting the starter from the tractor, that terminal on the starter must now be grounded to the tractor frame as the case of a converted started is still insulting. I tryind to keep from getting to high tect in my answer and instead I confussed. Sorry about that.
Bob
05-04-2004 23:33:15
 Re: Re: Re: Re: 12 VOLT SYSTEM in reply to MIKE HANLEY, 05-04-2004 23:29:34
Mike,
No appology to me is needed, because I understand the #^%$ system. I just thought your comments would further confuse the majority that DON'T understand the system!
