47 A NO COMPRESSION
Michael
05-04-2004 18:54:02
Just bought a 47 A, engine turns over good, good compression on left side but almost 0 on the right side. Does not make any "broken sounds" just no air coming out the plug hole.
Ben.So.Tex
05-05-2004 09:41:34
 Re: 47 A NO COMPRESSION in reply to Michael, 05-04-2004 18:54:02
Had the same problem on an A that I got a couple of weeks ago,(removed valve cover) Valves were stuck in the open, sprayed them with oil and then took a pair of chandle lock pliers and grabed the end of the valve stim and wiggle it a little and it came free. Hope your will be this easy. Good Luck Ben
Clooney
05-05-2004 03:54:03
Michael, the first thing? Are you testing with the carb & choke held wide open? If not re-run your test with the choke & carb wide open..
~Then as Pappy said, pull the rocker cover & look for a stuck valve or tight valve.. If nothing obvious found there take an old spark plug & break the porcelain center out of it, then braze an air hose fitting to the hollow spark plug shell.. Then roll the engine over until both valves on the low cylinder are closed, then install that plug [air fitting] in the low cylinder & hook your air compressor hose to it.. Where the air comes out you will find your problem.. If the air comes out of the air cleaner or exhaust pipe try swatting the offending valve stem top a few times with a hammer [maybe there is a piece of carbon or debris stuck between the valve & it�s seat. If the air comes out of the crankcase then suspect a broken or worn ring or worn/pitted cylinder wall.. The air will tell the story..
[email protected]
Pappy
05-04-2004 22:31:25
Sounds like an open valve or sticking valve. Check movement of valves and tappet clearance.
Set tappets to .020.
