B Dash
upikfarm
01-26-2004 16:14:08
I have a late model B serial number 297918.
I am the third owner. My problem is this. The dash has a place for a fuel control rod (G, F, O). The best I can tell this is a 52 model and it did not come with a fuel tank just gas. The second owner says the dash that is on it now came with the tractor back in 1972 when he purchased it from a local farmer. Has this dash been changed? I think it has and probably should have a place for the choke, 3 gauges, light switch, ignition switch, and I still have not figured out what the oblong hole on the right side of the dash is for. Does anyone have any pictures of a late B dash? or does anybody know what this dash should look like?
Clooney to the rescue!!!!!
Clooney
01-26-2004 17:19:55
 Re: B Dash in reply to upikfarm, 01-26-2004 16:14:08
upikfarm, there is a different [original] all-fuel & gasoline rear hood end cap listed for the late B.. There is only one replacement end cap & that fits both tractors so would probably have the G, F, O, markings on it.. Sounds like your tractor has the AB-4062R replacment.. Or someone put an all-fuel end cap on it at one time.. Any chance your B is an all-fuel tractor?
~That oblong hole [slot] is for the shutter control rod..
~I sent you a picture of the hood end cap on a gasoline late B..
[email protected]
Clooney [more]
01-26-2004 17:26:12
 Re: Re: B Dash in reply to Clooney , 01-26-2004 17:19:55
upikfarm, your E-Mail address came back as non operational..
Give me an E-Mail & I will re-send the picture..
[email protected]
upikfarm
01-26-2004 17:34:28
 Re: Re: Re: B Dash in reply to Clooney [more], 01-26-2004 17:26:12
You have me wondering now. maybe the carb has been changed and the dash is the correct one.
What was the lever under the throttle used for?
Clooney
01-26-2004 17:49:13
 Re: Re: Re: Re: B Dash in reply to upikfarm, 01-26-2004 17:34:28
upikfarm, You ask..."What was the lever under the throttle used for"...>>> Answ, to control the front shutters..
~If you move that shutter control lever you will see a short lever about 2/3 of the way down the steering support also move, that short bottom lever should line up with that slot in the hood end cap.. A rod runs from that short lever through the hood's lower right corner & on to the shutter linkage..
[email protected]
upikfarm
01-26-2004 17:24:26
Well I must be really off here. I thought the lever under the throttle control lever was for the shutters :( It has the DLTX 67 carb. Maybe that has been changed too.
Clooney
01-26-2004 17:30:06
 Re: Re: Re: B Dash in reply to upikfarm, 01-26-2004 17:24:26
upikfarm, that lever under the throttle lever does control the shutters but there is a link rod running forward from the bottom of that lever vertical rod to the shutter linkage on the front.. It runs through the bottom R/H side of the hood..
Ralph - WI
01-26-2004 17:02:31
Right bottom of bottom of dash would probably be for the shutter control rod.
upikfarm
01-26-2004 17:17:57
 Re: Re: B Dash in reply to Ralph - WI, 01-26-2004 17:02:31
I have a lever under the throttle lever for the shutters. I have a parts manual enroute just anxious.
