720 diesel how much plow?
Leeker
05-04-2004 09:06:27
Recently purchased a 720 Diesel basketcase. Put it back together; runs really great now. Looking for a plow to pull behind it..
Was told by former owner that he pulled 5x16's semi-mount with this tractor... I just can't imagine it having enough power for that set-up. We live in Northern Illinois, not the heviest soil in the country but also not the lightest. I am pretty sure the former owner is trying to be honest with me... He is afterall my grandfather...
So what can it pull, I was thinking 4-16's or maybe 5-14's What do you all recomend... Voices of exprience welcome...
buickanddeere
05-05-2004 05:43:25
 Re: 720 diesel how much plow? in reply to Leeker, 05-04-2004 09:06:27
Some characters will brag about pulling six or seven furrows while over ballasted and pounding along in 1st gear with a 720. They are wasting fuel, decreasing crop yields with compaction and wearing out the tractor prematurely. The 720 is supposed to be run at full rated rpms and at 80% of max rated load, leaving 20% for tough spots. Three furrows while running in 3rd or 4th gear is ideal unless in sandy soil.
GALEN EINSPAHR
05-04-2004 18:39:00
4-16 WAS MORE THAN ENOUGH PLOW IN HEAVY SOIL IN EASTERN NEBRASKA MORE OFTEN THAN NOT 720-730 WOULD PULL 3 16S IN FOURTH GEAR
MIKE HANLEY
05-04-2004 18:23:11
We have "plowed this ground" many times before. For those of you that were slepping in class,,,, It's all in the math. When a tractor was rated at NEB at the offical tests the pounds pulled in the offical test could be used as a sales tool wheather or not the tractor could really do the work anywhere, any time. A teacher can't teach without some sort of standsard is start from. So years ago the land grant colleges did a bunch of tests and decieded that it takes between 5 to 12 # of pull per sq in to turn soil in a plowing operation. This was excepted by the manufactors and must use the ave (5 plus12 = 17 div by two equals 8.5 So in rating a plow capasity of a tractor lets see what a 5 16" plow would require. The plow would cover 80" and require 8.5# of pull. so its 80" times 8.5. So for every inch in the ground it would take 680# of pull. If plowing 6" deep, it's 680 times 6. So to pull 5 16" 6" deep would take 4080# of pull. Now if we look at the NEB offical tests for the 720 Diesel. the 720 pulled 4644# in 4th gear at 4.17 MPH with 7.85% wheel slip.
By those standards the 720 could be sold as a 5 plow tractor.
So what happened between 1956 and 2004 that a 5 plow tractor can now longer pull 5 bottoms. Answer,,,,, depth for one reason and plow clearance for the other reason. Dropping the plow from 6" to 8" increases the pull required by an additional 1360# Besides haveing a standard plow depth of 6" the fore and aft clearance on plow built in the 50's were no where near the clearances of the new plows. In the 50's many corn fields yields were 50 Bu per acre and 80 was a good yield. A 100 bu crop and you would make all the papers. Most hay fields were mixed hay rather then straight alafala. Most guys had a rotation of corn, oats hay, hay. Most guys would disc the corn stalks twice so the plow wouldn't plug. Then when plowing up the second year of sod one would dig with a quack digger several times so to pull up and out the roots of the sod. (Remember now this is before spray weed killers) so to have weed free corn. So along came the fert "N" and the yields jumped. The land grant colleges are now pushing plowing deeper and pouring on the fertilizer. And along came higher clearance plow aqnd guys no longer disced or duhg before plowing. So there are all kinds of factors that need to be looked at when getting into this kind of topic. Plowing 6" deep a 50 Bu yield after discing twice and trying to compare it to plowing a 140Bu yield 8" deep without any other tillage can not be compared without adding in the common sense factor. Very fer guys around here plow anymore at all. It's eather no-till or chisel plow as the old moldboard plow will not put the fert deep enought aas what the land grant collages are pushing now. Common sense will tell you that a bean field will plow easer this year as when it was plowed last year after beening in alalfla for 6 years. Same way as when getting into topics like this. DON"T FORGET TO ADD IN THE COMMON SENSE FACTOR.
DON
05-04-2004 13:09:51
I HAD A CUSTOMER , HERE I IL.THAT PULLED A 6-14S PULL PLOW IN BLACK SOIL AND SOME CLAY, BUT HE DIDN'T PUT IT IN VERY DEEP. 5-6 IN AS I RECALL. SO HOW DEEP YOU PLOW IS A BIG FACTOR AS WELL. YOU PUT ON 3-16S AND PLOW 10" IN DEEP AND THE GUY BEHIND YOU WILL WONDER WHAT HAPPENED. DON
Britt
05-04-2004 12:20:02
In Upstate New York we used to pull a 4-16 three point mount plow behind a 720 gas. The soil was a sandy loam. The tractor would pull the 4-16 in third gear with no problem. Being a kid at the time, I tried it in fourth gear, but that was too much to ask out of the 720. When the soil dried out too much, it would pick the front wheels off the ground and you would have to steer with the brakes. (I guess that it needed front weights.) Anyway, the tractor had adequate power for the 4-16 plow. It probably would have pulled a five bottom in ideal conditions, but the 4-16 was a better match for that tractor. I don't think that you will go wrong with the 4-16 behind a diesel 720.
Good Luck,
Britt
Bo in Maryland
05-04-2004 12:54:07
 Re: Re: 720 diesel how much plow? in reply to Britt, 05-04-2004 12:20:02
..... ..just checked my 730 Operator's Manual and the section on "Capacity for Work" says the following....."Five 14-inch plow bottoms or the equivalent under most soil conditions".....
..... ..personally, I like Bill's suggestion of 3x16..... .for recreational tillage (which is all I do) I would rather under load a machine that's in it's fifth decade of service..... .
Good luck to all!
Bo
John T
05-04-2004 09:51:17
Leeker, Its been some years back and I owned several different 720's time to time (the first wife used a 730 Elec. start with 3 x 16 mounted I think), but in Southeastern Indiana semi heavy clay, I preferred a 4 x 16 when I had them (bought n sold stuff then, used whatever I had available). I didnt like to use a 14 inch, I like the furrow left by the 16 inch for my furrow wheel and in the farms I was in, a 5 bottom was simply tooooo o much for the 720's I owned at least. If I recall, I even used a 3 x 16 mounted once, and a 4 x 16 pull type, but like a semi mounted (steerable) plow the best. My best ever n fun plowing was when I used a dual on the left side using a semi mounted plow however. I trained the first wife to NOT turn slightly coming out of the lands end to round them off, which I hated, and she got picky n mad if I entered her plow lands lol.
Best Wishes n God Bless
John T
Ryan
05-04-2004 10:54:44
 Re: Re: 720 diesel how much plow? in reply to John T, 05-04-2004 09:51:17
What the former owner told you may explain the shape the tractor was in.....
Ryan
Bill
05-04-2004 09:40:34
Assuming you just want to play and your not planning on farming a few hundred acres with it I'd look for a 3-16 3pt plow. You can plow deeper, faster and not have to worry about lots of added weight on the tractor.
Mike M
05-04-2004 09:34:14
Soil means everything.I'm sure it could pull 5 in good conditions after all I have pulled 3 with a late model B. It may be better suited to find a 4 for all around uses and not be pulling at max. power all the time.I once had a 3 behind a 720D in alfalfa and would almost come to a dead stop then BANG something would pop and I'd go again they tell me it was the roots. My first thoughts were the tractor was bad.
Joe P.
05-04-2004 09:26:12
I grew up in Polo IL. My Dad had a 720 and 730. He had a 5-16 he would use on the 730 BUT only in stalks and at a less-than-full depth. For beans and hay gound he would use a 3-bottom. It probably would have handled a 4 but shallower and/or slower.
Russ
05-04-2004 15:20:21
 Re: Re: 720 diesel how much plow? in reply to Joe P., 05-04-2004 09:26:12
720D; SOUNDS LIKE A MOUNTED 3-16 WOULD DO YOU PROUD. WOULD BE NICE TO SEE A PHOTO OF YOUR RIG AND PLOW COMBINATION WITH A PATCH OF DARK TOPSOIL TURNED OVER AND EARLY BIRDS SNACKIN' THEM CRITTERS.
