8640 boils over
Walt
05-04-2004 08:33:42
More trouble with my 8640, When I work it hard the temperature is fine but intermittantly it purges coolant out of the over flow at the rad.
I ran it with the cap loose and it was OK for about 30 Min. the all of a sudden the water started gushing over the hood.
I did notice bubbles in the fluid, Any ideas where I should point my focus to repair this.
buickanddeere
05-06-2004 05:30:05
 Re: 8640 boils over in reply to Walt, 05-04-2004 08:33:42
If the cylinder head bolts were re-torqued, the injection pump set back down to stock HP and the engine allowed to fully warm up before being fully loaded. And propylene glycol anti-freeze used instead of ethylene glycol. The propylene doesn't ruin bearings as fast. You make be able to limp her along for a while.
Walt
05-07-2004 07:22:55
 Re: Re: 8640 boils over in reply to buickanddeere, 05-06-2004 05:30:05
I think I'll give it a try, If it get worse yhen we probably should look inside.
Lee
05-05-2004 02:36:12
BuickandDeere has it nailed. The 'O' rings on the cylinder sleeves and/or the head gasket do this and it's 'normal'? 4640 had two cups of antifreeze on top of the oil drain plug with a crankcase full of blackest of black oil. That can only mean that the O rings are leaking when it's cold (probably bitter cold?). 4630 sat for several months (a rare condition for it) and when first started, blew the cap and purged 5 gallons of antifreeze in three seconds - no work done on it for that and both still fine tractors several years later. Situation normal?
I'd try a couple bottles of Bar's leak and just keep an eye on the antifreeze level, sure cheaper than an overhaul which may not fix anything to start with.
Brokenwrench
05-04-2004 17:11:08
It could be what was mentioned below,but that would usually also cause an overheat problem.Could be a weak radiator cap,or if you had drained the cooling system you might have an air pocket.
DON
05-04-2004 13:15:07
I THINK BUCKANDEERE IS RIGHT , WHILE IT'S DOWN HAVE THE RADIATOR BOILED OUT. ITS MOST LIKELY PLUGGED INSIDE. DON
buickanddeere
05-04-2004 09:09:18
Head gasket or sleeve "O" ring.
