JD D cutting out
Kelly
01-26-2004 16:02:28
1948 d The fuel shut off was hard to turn and broke at cotter key and was left on.Which flooded the tractor bad.I cleaned the shut off and its fixed. I changed the oil and filter.I filled the radiator maybe to full.After i start rolling it starts to cut out. I noticed water coming out from under the radiator cap.Could this be the problem it getting on the plugs or did the floodig fowl the plugs.Can you get new gaskets for the Ra.cap.
Clooney
01-27-2004 03:44:45
 Re: JD D cutting out in reply to Kelly, 01-26-2004 16:02:28
Kelly, you probably still have a lot of fuel vapors in the engine like up in the governor, or rocker cover, or in the 1ST reduction cover area.. Those fuel vapors can get pulled in through the intake valve guides or past the piston rings..
~Put in a new set of spark plugs then take the tractor out & work it for a while to see if your miss goes away..
~On your radiator leak?.. Maybe you just overfilled it [it needs room for expansion] ..
~On the gasket leaking?� Probably can still get the gasket from Deere.. If not, E-Mail me & I will give you a few aftermarket places that might have that gasket..
[email protected]
Kelly
01-27-2004 17:00:49
 Re: Re: JD D cutting out in reply to Clooney , 01-27-2004 03:44:45
THANKS FOR THE INFO. Clooney
