JD 316 Newbie
Dale in I'N'
01-26-2004 15:52:08
Hey guys, I usually hang out on the "N" board, cus my 'N' is my sweetie, but I gotta problem, I think. I bought a 70's model JD 316 this summer at an auction. It's great... It has hydrualic's w/ front blade. Have been plowing out driveways today for friends & ole folks. The thing is fantastic !!! I have looked over and over to find a place to check the tranny and hydro fluid. Looked at Deere.Com and search this forum and arc's. Where is it at ?? Thanks in advance.
Bob
01-26-2004 16:04:17
 Re: JD 316 Newbie in reply to Dale in I'N', 01-26-2004 15:52:08
There should be an exposed loop of clear plastic hose to the rear or left of the hydro unit where you can visually verify the level of the oil. If I recall, there are some variations, by serial number.
An operator's manual is about $25 or $25 at Deere Technical Publications.... 1-800-522-7448.
Dale in I'N'
01-26-2004 16:10:56
 Re: Re: JD 316 Newbie in reply to Bob, 01-26-2004 16:04:17
Thanks Bob, If it is low where do I fill it at ? THanks again very much.
Bob
01-26-2004 16:32:01
 Re: Re: Re: JD 316 Newbie in reply to Dale in I'N', 01-26-2004 16:10:56
What's your serial number? I have one or two 316 owner's manuals, and will take a look later tonight, if I have the serial number.
You may have a pipe sticking up under the rear deck with a hexagonal pipe cap on it, for the fill port.
Dale in I'N'
01-26-2004 18:01:50
 Re: Re: Re: Re: JD 316 Newbie in reply to Bob, 01-26-2004 16:32:01
Bob, Thanks went out and found clear hose. I have rigged up a rear weight ( Milk crate filled with chains and pipe stuff.. bolted where the hitch mount would be ) so I could not see the tube, but found the pipe with hex cap. I know this isn't per spec, but filled it up with 20 wt that I use in the 'N' tranny.
Al
01-26-2004 18:20:50
 Re: Re: Re: Re: Re: JD 316 Newbie in reply to Dale in I'N', 01-26-2004 18:01:50
316, your tranny/hydrostat should have a tranny oil. JD sells the "recommended" but I think auto transmission fluid is real close. I have a 318 so it should be the same.
