JD 2440 tractor info needed
Bill
05-03-2004 22:02:57
There's gonna be a John Deere tractor model 2440 for sale at an auction this weekend in Sanford, NC. I don't know much about the tractor's history- I don't think this model is still in production though. I'd like some info on this model.
What is its horse power? Is it a Cat 1 3pt hitch? Any known flaws on this model? Thanks.
Bill
buickanddeere
05-04-2004 08:39:40
 Re: JD 2440 tractor info needed in reply to Bill, 05-03-2004 22:02:57
As long as someone read the operators manual and put Hy-Guard in the transmission istead of 90wt gear lube. Kept HD diesel antifreeze in the rad that wasn't allowed to go acidic. And greased the clutch throwout bearing on occassion they are excellent. If you see any "silver" flecks in the trans/hydraulic oil, run away fast. That's brake backing material ground up after the friction material rotted off. Due to the wrong oil being used. Test drive and feel if one or both brakes grab or squeal.
Indydirtfarmer
05-04-2004 03:55:20
Jimmy (below) summed it up pretty well. The 2440 is a great tractor. The "earlier" run was built in the U.S. Later version was made in Germany. The only "problem" in it's run, was a tendancy towards "electraulisis" where rust particles in the cooling system erode the base of the cylinder sleeves, causing coolant to enter the crank case. There are treatments for the coolant, and filter systems for the coolant also. Some 2440's were equipped with a "Hi-Lo" transmission. A (very good) John Deere (dealer) mechanic once told me that it added as much as $1000 to the cost of splitting the tractor, should you need a clutch or any other simalar repairs. Deere rated them at 60 HP. Like most other tractors, most would dyno more than their rating. Mine has consistantly dynoed at 67 HP. over the years. With fluid in the rear tires, and front weights, I have pulled a 4 bottom, 14" plow before. It's more at home with 3 x 16" though. They make GREAT loader tractors. Great balance. Good power to weight ratio. All the "big tractor features". Some options to look for; Hi-Lo tranny, reverser, Independant OR live PTO, mid-mount PTO, telescopic 3 point lower links. Row crop or utility versions. Rops and canopy. Differential lock. (multiple)hydraulic remotes. Good luck with purchasing the 2440. Let us know if you get it. You'll be very happy with it. John
Indydirtfarmer
05-04-2004 04:05:51
 Re: Re: JD 2440 tractor info needed in reply to Indydirtfarmer, 05-04-2004 03:55:20
Also, They were produced from 1976 (as a 1977 model) to 1982. Don't let the "age" scare you off. They are from the era when tractors were at their best. (No electronics, plastic, ect.)
Pete/ME
05-04-2004 03:45:38
I had one ten years ago with a 145 loader. Excellent tractor. Only sold it because of short $. No problems, plenty of power, it has a cat. 2 hitch. With low hrs. (5-6k) w/out loader, I'd pay $7k to $9K here in Maine.
Russ
05-04-2004 17:06:55
 Re: Re: JD 2440 tractor info needed in reply to Pete/ME, 05-04-2004 03:45:38
JD 2440; 1978, 4CYL, 219CID DSL, 16F-8R, 60HP PTO, 4855LBS, LO 6400, MID 8580, HI 9870. KEEP THOSE DRAWBACKS IN MIND AS MENTIONED BY THE OTHER GUYS AS YOU SIZE IT UP PRE-AUCTION HOURS. HOPE YOU GET A GOOD DEAL. GOOD LUCK.
Indydirtfarmer
05-04-2004 04:02:26
Forgot a few things. In the Southern Indiana/Kentucky area, you MIGHT find one for as low as $8000, but can expect to pay as much as $12000 for one with low hours. (Loader might add another $2500) Mine has around 1400 hours. I have a neighbor that's trying real hard to get me to sell mine. He's offering me $12500. (Still won't sell) As was mentioned, it's got a cat. II hitch, but will handle cat.I impliments with a mere switch of the sway blocks, and using bushings. Time to get to work! Good luck. John
Jimmy
05-04-2004 01:38:47
Howdy,
The 2440 was produced in two different series, succeding the 2030. The older series has the hood sloping upward like the new gen. tractors and may have a park feature on the tranny. The new series hood sloped down like the gen II tractors and usually has an emergency brake. It has a 4-219 (4 cylinders, 219 inches) engine in it and produces 60 hp. It is a good tractor for box blading, mowing, haying, and so forth. Not much to worry about, they are built rugged. I think it is one of the best tractors JD made; just my $.02 worth.
