Mark, First of all, they can be almost totally shot and turn easy when the frame is up on a jack, so that dont tell you all that much. One condition which could cause it to turn fairly well for some distance BUT THEN TIGHTEN UP, would be where the half moon Sector Gear was adjusted too close against the Worm Gear. Thats cuz most of the wear is in the straight ahead center of gears position, and then as you turn she could become over tight n bind. Too much horizontal fore n aft end play in the steerign shaft could be cuz the end bearing pre load is too loose which is to some degree adjustable by removing the end beraing cap (2 horizontal bolts) and taking out some shim/gaskets. HOWEVER, I dont think thats the cause of the tight steerign as you described it, thats more of an excess shaft play which can cause wobble when roading. Good steering also requires god matched and aired up tires n wheels,,,,proper wheel bearign adjustments,,,,,proper horizontal shaft end play and pre load adjustment,,,,, ,and NOT WORN OUT worm n sector n bushings. If the problem is that the sectors too close against the worm, its adjustable by removing the vertical bottom set screw and rotating the eccentric bushing to move the gears farther apart, then replacign te set screw in another half moon stop hole location. Ive had some sector gears a lil tough to get loose, on some we had some pry/pinch bars we could get to just go under a portion of the sector,,,,, ,, then had the tractors wheels jacked just off the ground,,,,, ,,,had the top nut loose and just to the threads top (to protect threads),,,,, ,had a piece of hard oak on top,,,,, ,and hammered down on the top with hard shocking blows and it released. Lt us know how you come out and be sure n take a look at that sector to worm clearance issue (adjustable by eccentric bushing rotation) should it turn easy but then bind cuz they are too close. Goof Luck n God Bless ya John T
