JD A steering/reassembly advice please
barryinmn
05-03-2004 19:39:55
The old gas tank has a dime sized hole in it along with a huge ammount of rust.
I picked up an excellent shape replacement gas tank last weekend at the MN 2 cylinder club meet $45 probably less than fixing the old one.
Now for reassembly: what type oil/grease do I put in the nose? It was empty when I took it apart. Also what type of packing material for the shaft nut should I use?
Would automotive type gauges work for amp, oil & water? It looks like there is a simple coiled wire from the ammeter to the ignition switch. Generator wires do not feel brittle so will reuse.
