jdemaris
05-04-2004 05:34:59
Re: Re: Re: 1520 won't start in reply to Bryant, 05-03-2004 19:13:46
Deere has had a cranking problem for years with all its equipment that uses closed-center hydraulics (like your's). When all is perfect, the hydraulic pump is supposed to shut all hydraulic flow off when you start cranking the tractor - but there are many parts that get slightly worn - and once they do - the tractor will barely start - especially when hot. Tends to burn up a lot of starter motors. Sometimes just jiggling the steering wheel will help. I don't want to go into all the possible hydraulic leakage problems. But, most are minor and are not worth fixing. I worked for three Deere dealers since the late 60s - and we installed manual destrokers on all our problem tractors. I always carried a bunch with me in my tool box. Cost around $3-$5, and takes a few minutes to install. You have to walk to the front of the tractor, and turn "turn the pump off", then start the tractor, then turn it back on. I know of many tractors that will not start without them once hot. There are other remedies that cost more. For instance, we installed diesel starters on a lot of gas engines to give them more cranking power. Also, Deere provides an electric destroker kit. This turns the pump of with an electric solenoid whenever the starter is cranking. The kit is EXPENSIVE. Especially for an older tractor - that because the old pumps were not ported to allow simple installation of the solenoid. So . . . the pump needed to be removed, a whole new control valve housing installed, pump bearings re-shimmed, and then put back together. We were getting over $400 for the job back in the early 80's - probably cost more now. Now, if you tractor has had a replacement pump installed, it might be ported for the solenoid and is plugged. In that case, you can install a solenoid in a few minutes. The most common hydraulic problem for your tractor is the stroke-control valve in the pump. When it gets worn it tends to make a hammering sound, slows or sometimes stops the hydraulics, and makes starting miserable. It's replaceable without removing the pump. Now, with your sitution - I still don't understand. If you checked voltage in "crank" position, but the engine was not cranking, why not? If you had access to a hand-held battery load tester that uses a carbon-pile, you could quickly diagnose the problem if it's not cranking. First, check the big pole on the starter solenoid and make sure you can draw good current from it. It should read the same as if you were checking right at the battery. If it tests good, then you know it's not a battery current delivery problem (like bad cables, bad batteries, etc.). Next, jump the connection between the little "S" terminal and the big pole. That should energize the solenoid and make the starter crank. If nothing happens - no sound - no nothing - you probably need a new $20 solenoid. If it "clicks" but nothing happens, then again the solenoid may have bad internal contacts so it cannot close the starting circuit - or - it IS closing the circuit but the starter itself has internal problems. The flat copper bar that connects the bottom of the solenoid to the starter carries the current into the starter. You can test for current there when the solenoid is engaged. If you turn the key, and no power is getting to the "S" terminal, than there are many things to check, e.g. neutral safety switch, circuit breaker, key swith, etc.
