Fuel problems on B
Scott
05-03-2004 18:21:12
Finally got my 1945 B running initally. I shut fuel valve off and let it run out of gas the last time I ran it, now when I crank it over no fuel is spraying out of the compression releases and the tractor does not start. I undid the fuel line and gas is getting to the carb. The carb was cleaned and gone over by the JD dealer prior to me getting the old B running. What should I check now? Thanks
old
05-03-2004 20:55:44
 Re: Fuel problems on B in reply to Scott, 05-03-2004 18:21:12
Sounds like the float needle is stuck. You might try tapping on the carb with the fuel on and the drain open. That will tell you if you have knocked it loose.
