G questions
JD G GUY
10-21-2003 21:16:07
I had to put a headgasket in my G.. sounds simple dont it. well i got the valve cover off and the rocker arm shaft bracket on the clutch side is broken right above the nut to about an inch and a half above there. it still holds the shaft in place with it broken, so i was wondering if i could JB weld the peice back on or will i need to replace the bracket or could i get away with fixing it somehow, I was told it might be able to be brazed. Another question is about the hydraulics, right now it has the quick release connectors on the back for running a remote cylinder. i was wondering if those would have to be pluged to use the lift arms on it or is something else wrong, i just might not know what im doing either any help would be greatly appreciated
Dan
10-22-2003 06:57:44
 Re: G questions in reply to JD G GUY, 10-21-2003 21:16:07
Assuming you hae Power trol hydraulics, you need a special plug that goes in the holes where the cylinder plugs in to use the rockshaft. The plugs look similar to the cylinder quick couplers but have holes in different places to route oil.
Navy Chief
10-22-2003 06:25:38
Mornin "G" Guy;
I cant be of much help in the hydraulics arena, but as for the rocker arm shaft bracket, you could possibly repair it, but my 2cents on it is better to spend a little now and get a replacement, than to attempt a fix and have a major catastrophic failure later.
R/
Eric
