HOW TO LOOSEN (RUSTED REAR HUB BOLTS ON JD 630)
MIKE LOKAI
05-03-2004 17:49:36
BEFORE DOING SOMETHING I'LL REGRET, ANYONE HAVE ADVICE ON HOW TO LOOSEN REAR WHEEL HUB BOLTS ON A JD 630, THE CENTER BOLTS THAT LOOSEN THE HALF OF THE HUB ARE STUCK, THE REMAINING THREE BOLTS THAT TIGHEN THE HUB ARE OK . SURELY THIS QUESTION HAS BEEN ASKED MANY TIMES BEFORE. THANKS IN ADVANCE.
Ron
05-03-2004 21:38:48
 Re: HOW TO LOOSEN (RUSTED REAR HUB BOLTS ON JD 630 in reply to MIKE LOKAI, 05-03-2004 17:49:36
Pull the 3 bolts out and Load the hub with penetrating oil...!! I haope you are using a 3/4" breaker bar, and have you tried a 4 or 5' pipe on the end of it..?? If so, Soak the hub with penetrating oil...heat on the hub may help too....It will take about 1/2 hour with a Blowtorch to start to get it hot...don't heat the bolts too hot-- you don't want to take the temper out of them..!! Those Jack-Bolts can get rusted tight..!!
ChuckW
05-04-2004 08:18:06
 Re: Re: HOW TO LOOSEN (RUSTED REAR HUB BOLTS ON JD in reply to Ron, 05-03-2004 21:38:48
believe it or not, impact and jarring works quite well. If you have a good compressor and 3/4 " impact, just keep working back and forth. The crude will break and keep working out of the hole and threads this way.
