4020 hard starting
Kraig
05-03-2004 08:19:31
The 4020 I am working on will start the first time good but if you shut it down and try to restart it won't unless you wait a little while. Does this have to do with the hydraulic pump or is it something else, thanks.
Kraig
05-04-2004 05:49:16
 Re: 4020 hard starting in reply to Kraig, 05-03-2004 08:19:31
The tractor cranks really good the first time and after you shut it off and retry it cranks so slow, almost doesnot at all. Where do you get a manual destroking valve, guess I will call Deere, I am going to uncouple the pump to verify, thanks for the help.
jdemaris
05-03-2004 19:04:18
Just going to add a little to what Broken Wrench already stated. The electric destroker can easily cost a couple of hundred dollars unless you have a new-style pump and not the eight-piston pump the tractor came with. The original 4020 pump has NO provision in its valve assembly, so the entire valve-body must be replaced. Much easier and cheaper is to add a manual destroker. Cost less then $5 and installs in five minutes instead of a days work. You did not state if the problem is one of just not starting, or of slow cranking and hard starting. If the latter, then it's the hydraulics which is common. I put manual destrokers on my neighbor's two 4020s and one 3020 twenty-five years ago. They will not start, once hot, without them. My 1020 and 300 are both the same way. If you problem is not starting once hot, but it still cranks fast, you probably have a worn head-and-rotor in the injection pump. When they get scored, they often won't start at all at cranking speed until they cool down.
Brokenwrench
05-03-2004 14:09:02
You probably have an internal hydraulic leak that is calling for the main pump to pump while you are cranking. You can use the tried and true method of turning the steering wheel side to side while cranking,until you find the source of the internal leak.This relieves hydraulic pressure while cranking. If you can't track down the internal leak,you can install an electric destroke solenoid on the main pump,which destrokes the hydraulic pump while cranking.
WTW
05-03-2004 10:26:45
Kraig,
Is this tractor a gas or A diesel? If it is a diesel it is most likely fuel related as in leaking delivery valve in injection pump. What happens is when engine is warm the fuel gets thinner delivery valve leaks more and at a cranking RPM the injection pump will not deliver enough fuel to start the tractor. If this is the case watch the exhaust for smoke when cranking when this problem occurs, if it is getting fuel and not starting it should be emitting some smoke.
Chris
05-03-2004 08:33:14
We had a International that would do that. It turned out to be the coil. I would look at the ignition system first. Maybe replace the condesor or try another coil and see if it helps.
