AR throttle shaft bushings
RonMC
05-02-2004 23:45:28
I'm sure someone can answer this one - I got a carb kit for my AR and it comes with new shaft bushings.I got it from the dealer, but it's not an original J-D part. Is it usually necessary to hone these to get the shaft to operate properly or can I do a nice careful installation (no "mushrooming" and use as-is ?
Earl S.
05-03-2004 09:22:35
 Re: AR throttle shaft bushings in reply to RonMC, 05-02-2004 23:45:28
I don't think anyone can make a bushing that when you press in place that it won't make the inside of the bushing out of round.Usually it will be out of round a little less than the press fit. I always ream my bushings.You want that bushing to be a perfect fit as to not pull vacuum,but still the throttle shaft has to be free.Too tight will effect the governor function.I find the plating on the new throttle shafts to be a problem when trying to fit. I put the shaft in a lathe or drill and lightly polish to remove high spots on shaft.If the slot where the throttle plate goes has too much clearance ,when you tighten the throttle plate screws it will bend the shaft.Some are too narrow.There are reamers made to ream cast valve guides and there are reamers made to ream bronze so make sure you order the right reamer, Goodson (1-800-533-8010)www.goodson.com can supply you with the correct reamer.Throttle shafts vary in size so mike it to get correct reamer.I hope this helps.Email if you need help. Earl In Illinois
Ralph - Wi
05-03-2004 08:04:36
Just installed one in slant-dash A that required no reaming. bottom bushing was not replaced.
John T
05-03-2004 07:41:04
Ron, the answer is "it depends". Ive replaced some that didnt need any fine tuning, but on many, the shaft was a tad too snug once installed. I use lithium based grease in the bushings and on the shaft when assembling and then give them a lot of exercise. I like a snug but smooth fit there, but one cant depend on the grease and the shaft still has to operate free after any lube is washed out. Placement of bushings or sleeves etc in a freezer prior to installation may help get them installed without mushrooming, but still its how they fit at temperature and after the exit of grease that's critical.
Good Luck n God Bless
John T
Clooney
05-03-2004 03:27:47
Ron, I have always had to ream those new throttle shaft bushings.. They always seem to be slightly tight even when pressed in with a stainless driver I made for specifically driving them..
[email protected]
RonMC
05-03-2004 09:04:05
 Re: Re: AR throttle shaft bushings in reply to Clooney, 05-03-2004 03:27:47
Thanks guys ! I guess I might be "on the bum" at my J-D friend's shop for his press and reamers.
