8640 fuel pump
Walt
05-02-2004 19:52:10
I am having some concerns about the governor on my nippondenso fuel pump. When I work the tractor hard it looses Revs. My turbo Fuel Pump and Injectors have been recently rebuilt but it lacks the snappy response. If anybody has hade a similar problem I'd like to here their cure?
Thanks Walt PS. could this be a fuel pump timing issue?
Wayne
05-03-2004 06:09:13
 Re: 8640 fuel pump in reply to Walt, 05-02-2004 19:52:10
Sounds like you have a fuel problem. No fuel or not enough fuel will cut down on HP and also if just a small amount will cut back on RPM's also.
Bob
05-02-2004 19:57:50
Check transfer pump pressure at the injection pump. I don't recall what the pressure's supposed to be, but find out, and then put the tractor under load and see if the transfer pressure drops.
The "dip tube" that hangs down into the RH fuel tank on these tractors is known to plug, or possibly develop a crack. Either way, fuel flow TO the transfer pump may be restricted.
david val
05-03-2004 01:45:20
 Re: Re: 8640 fuel pump in reply to Bob, 05-02-2004 19:57:50
also check that the tube from the manifold to the aneroid is not leaking, also, if i remember well, the fuel tanks are not vented but pressurized by boost pressure, check the plumbing.
david
Walt
05-02-2004 20:01:16
Thanks Bob I'll check it out.
