Hi All,I have a problem where the motor runs only for a few seconds, then quits. Considering either the fuel injector pump or the fuel pump, I ended up having the injector pump rebuilt. At the time, I cracked a fitting or two and convinced myself fuel was being delivered to the injector pump - no formal measurements were made however. I had the injector pump professionally rebuilt and was told that there was a piece internally that was broken - apparently it's a common piece to go... I put the injection pump back on the tractor and while the problem seems slightly better, it's still there. When the tractor is started, it'll run for a few seconds at a relatively high rpm, then quit. It'll run a bit longer at low rpm. After it quits, if it's allowed to sit for only a few seconds, it'll start again, then quit... My only two thoughts now are either I did something wrong during the install of the injector pump or it's the fuel pump. Any ideas? I appreciate any help. While I've been turning wrenches for fun for a long time, I have very little experience with diesel. Heck, I just learned how to spell the darned word! Thanks again in advance. Curt
