35 B rocker arms won't stay up
SteveA
10-21-2003 20:29:50
A friend has brought his 35 B back from years of non-use and the rocker arms will raise but won't stay up. While he was reworking it, he examined the cylinder parts and they looked good. Any suggestions on what to look for will be helpful. thanks, Steve
Clooney
10-22-2003 03:45:08
 Re: 35 B rocker arms won't stay up in reply to SteveA, 10-21-2003 20:29:50
Steve, it could be a few different things. ~It also depends on if it has a Power-Trol or power-lift on it. [does it have foot pedals or a lever to control the rock shaft?]
~It also depends on if it�s losing rock-shaft oil? [is the oil level staying up?]
~The first place that those units tend to leak is the rockshaft lift piston seals. Even if they look good there is still a very good possibility they can leak down.
~The other places are the control valves, housing gasket, or porosity in the case.
~Let us know if it has Power-Trol or power-lift & we can be a little more specific on how to isolate the leak area..
[email protected]
SteveA
10-22-2003 08:32:55
 Re: Re: 35 B rocker arms won't stay up in reply to Clooney , 10-22-2003 03:45:08
Clooney, thanks for the reply. The tractor has the foot pedals and the rockshaft is either full up or full down, no in-between. This old fellow is enjoying this tractor that he farmed with long ago. He built a 3-point adapter for it so that he can use a mower. Steve
Clooney
10-23-2003 04:02:47
 Re: Re: Re: 35 B rocker arms won't stay up in reply to SteveA, 10-22-2003 08:32:55
Steve, on those power-lifts the usual problem is the piston seal. If the P/L unit is losing oil then suspect either a cylinder to housing gasket or P/L box to housing gasket failure...
[email protected]
SteveA
10-23-2003 08:00:11
 Re: Re: Re: Re: 35 B rocker arms won't stay up in reply to Clooney , 10-23-2003 04:02:47
Clooney, thanks, I'll pass this on to my friend. Steve
