146 Loader on 2510 or 2520
Paul
05-01-2004 19:42:32
People have noted they have put a 146 Loader on a 2510 or 2520. The dealer tells me the 146 Loader is made for utility tractors.
Can anyone tell me more about what they had to do to get a 146 loader to fit a 25XX? Did the loader go down far enough? Did it still give sufficient hight to stack round bales? Does anyone have any pictures?
Thanks, Paul
John51
05-02-2004 16:57:39
 Re: 146 Loader on 2510 or 2520 in reply to Paul, 05-01-2004 19:42:32
Yes, I have a 146 loader on a 2520. The frame on all those JD tractors was the same width, including most utilities, so it's a fairly straight forward job. I took the mounting brackets and drilled holes to match the tractor frame. I have a lot more bolts holding it that way than the original mounts. And I figure that tractor isn't too big for the loader because it's listed for some of the big utilities which weigh more and have more hp than a 2520. It will go below level to dig, and I can stack big round bales. I don't know how high it goes but I can check my book. I can also take photos and email the info you need. Check my email address and get in touch. By the way, where are you located?
Paul
05-02-2004 19:23:33
 Re: Re: 146 Loader on 2510 or 2520 in reply to John51, 05-02-2004 16:57:39
John51
You should now be able to e-mail me. I am Paul in LaCrosse, Wisconsin. Yes, I would be very interested if you have any pictures.
Thanks.
John51
05-03-2004 04:58:14
 Re: Re: Re: 146 Loader on 2510 or 2520 in reply to Paul, 05-02-2004 19:23:33
Paul,
Your email address will not come up. I think mine will. Email me and I'll reply.
John
David
05-02-2004 08:41:54
I just checked my 146 owners manual and it does not list the 2510/2520 tractors as "approved tractors". Obviously, that doesn't mean it won't work or can't be retro fitted... good luck
