520 spark plug problem
Curt
05-01-2004 17:21:49
My Dad and I have a 1957 520 and it is fouling sparkplugs every two months. New wires and cap haven't helped. We currently are using Champion plugs D15Y. Any suggestions or possibly a different/better sparkplug would be appreciated. Thanks, Curt
Clooney
05-05-2004 11:26:03
 Re: 520 spark plug problem in reply to Curt, 05-01-2004 17:21:49
Curt, the specified plug for that 520 is the Champion D-16 or equivalent & that was for older gasoline that ignited easier than today�s emission compliant gasoline�s .. Your plug is way too cold for anything other than flat out full time work..
~If you are only using it for light duty then I think you will find the Champion D-23 [or equivalent] would work great.. If you are going to work it hard most of the time then a Champion D-21 [or equivalent] would be in order..
~Most plug fouling problems on the 520 are caused by running a plug that�s too cold [your D-15Y is too cold]..
~I have been running the D-23 in my 520 for years [same plugs] & I run it on the rich side for a low steady idle & good throttle response. That 520 tractor will idle down to about 200 RPM�s or less with no problems, probably the best idling tractor I own..
~One last thought� If you are only playing with that tractor & not working it you might want to turn the manifold heat valve to {hot} as that helps the fuel in the carb vaporize easier..
[email protected]
buickanddeere
05-02-2004 11:57:12
What is the coolant temp and how has the idle and main ajustments been set on the carb?
Chuckw
05-02-2004 05:15:19
Curt, save yourself some time/money/and go with electronic ignition. This will stop your fouling problem. I get mine from Genesee Electronics.
John T
05-01-2004 20:53:28
Curt, I have good luck with Autolite 388 which is a heat range hotter than the 386 I believe would be the original heat range plug.
QUESTION FOR OIL OR GAS FOULING: When the plugs foul, are they a flat black colored sooty powdery coated or a wet uneven shiny black coated???
The first may be due to running at too rich carb settings or a restriction in the air intake or air cleaner bowl is all clogged up or air pipe or a choke butterfly plate thats not openng fully. If so, it would exhibit excess black smoke out the stack, does yours ???? You may try n lean the carbs bottom center metering adjuster screw if shes black smoking. Check the air cleaner bowl for water or crud and if the air cleaner mesh and air pipe is clean and insure the chokes opening n staying open fully if shes black smoking and you adjusted the bottom metering screw.
If the rings and/or valve guide are worn excess and she throws some blue smoke out the stack and crankcase blow by, the plugs may be oil fouling, which leaves more of a wet shiny uneven coating and fouls the plugs. Have you ran a compression check lately?? and is there much blue smoke out the stack and blow by????
IGNITION CAUSES: Try a fresh set of Autolite 388's,,,,make sure your plug wires are wire core and NOT carbon suppressor types,,,,, ,inspect the ignition points and the proper gap and REPLACE THEM if they are burned or pitted or carboned up or heavy gray oxide coated. Check BOTH plugs to see if they are producing a good visible blue and NOT a faint thin wimpy yellow spark. If the spark isnt a good blue, then check the wires as I said above and the points and replace the condensor if any doubt of its condition and be sure the cap is clean and free of moisture or cracks or carbon traces.
To eliminate any cap or rotor or plug wire problems, remove the coil wire from the distributor cap (leave coil end in coil) and crank her over and see if the coil wire end produces a good blue NOT a faint thin wimpy yellow spark approx 1/8 inch away from tractor iron.
If the spark is still weak direct out trhe coil despite good and proper gapped points and a good condensor, it may be time to check the coils input voltage (6 TO 8 volt range if a ballast system with ignition on and points closed) and the condition of a ballast resistor (its ohms around 1.5 to 1.85) assuming it has one. If no ballast, the coils input voltage would be near battery voltage of 12.
It also helps reduce plug fouling if the tractor is ran up to temperature and used under a load.
If you like I can e mail you a copy of the reducing Plug Fouling Article I had published in the March issue of the Green Magazine.
SUMMARY, (A) IGNITION: Try fresh hotter plugs,,,,, use wire core plug wires,,,,, ,replace points if burned or pitted or carboned or heavy gray oxide coated,,,,, ,Check for a good blue spark at BOTH the coils output wire and the plugs themselves,,,,, ,,Check for approx 6 to 8 volts on the coils high input (NOT to distributor) side with ignition on and points closed or near 12 if no ballast and a 12 volt coil.
(B) Fuel: Be sure of no air restrictions and a clean air cleaner bowl and mesh and the chokes opening fully. (C) CARB: Be sure youre NOT running over rich. (D) Run up to temperature.
If the ignition and fuel and carb are all good but the rings or valves are causing low compression and/or blue smoke and excess blow by, hotter plugs may help some, but they may still foul prematurely.
Good Luck n God Bless, post back or e m ail [email protected] any questions.
John T
Curt
05-02-2004 05:33:58
 Re: Re: 520 spark plug problem in reply to John T, 05-01-2004 20:53:28
Thanks for all the info.
John T
05-02-2004 07:33:23
 Re: Re: Re: 520 spark plug problem in reply to Curt, 05-02-2004 05:33:58
Youre most welcome, let me know what you find and how it turns out, John T
Ron
05-01-2004 19:30:52
For light work, I would use D-21 Champions..
I am sure others like AC or Autolite plugs ( so do I )... The D-15 may be too cold for what you use the 520 for...
