4320 oil leak out clutch insp.cover
mike
05-01-2004 04:50:50
I have completely resealed and it still leaks took back apart and checked all the seals and orings every thing ok has anyone herd of a crack or bad spot in the housing the oil apears to be coming from the rear of the center housing its not the pto leaking and it is hydraulic oil
JDBert
05-03-2004 07:33:24
 Re: 4320 oil leak out clutch insp.cover in reply to mike, 05-01-2004 04:50:50
Sorry, but I was wrong theres a oring inside and a SEAL on ther shaft. Those piston seals have a tendency to leak to and when you install new ones you should install the pistons new too. I have a 4620 that I never have been able to keep those pto engagement seals from leaking. They are at the clutch to tranny split too, on the tractor half.
chris
05-04-2004 20:26:52
 Re: Re: 4320 oil leak out clutch insp.cover in reply to JDBert , 05-03-2004 07:33:24
Don't forget to adjust the pto valve, that's why the orings are leaking, when out of adjustment the pistons fluttering there and chew up the orings.
mike
05-03-2004 07:56:06
I put new seals backers and piston in shouldn't that leak when using the pto only it leaks when not using the pto thanks
JDBert
05-03-2004 15:18:37
 Re: Re: Re: 4320 oil leak out clutch insp.cover in reply to mike, 05-03-2004 07:56:06
Yes that part wont leak unless using the pto. But the stub shaft will leak all the time (when running) if the oring and seal is bad
chris
05-01-2004 17:30:14
Did you happen to take the inspection cover off on the bottom side(if equipped), to help you diagnos this while the tractor was running. So you're saying the oil is coming from behind the pto piston assembly/fork for traction clutch, and it's not the seal for the pto drive tube that goes into the back housing behind the center housing. Maybe its the gasket between the two housings? Are the bolts tight between the housings? chris
mike
05-02-2004 04:14:34
 Re: Re: 4320 oil leak out clutch insp.cover in reply to chris, 05-01-2004 17:30:14
bolts are tight and gasket is new the the way the leak apears to look like the pto shaft seal is leaking but it is not i removed the shaft there is no oil on front of the seal or shaft
JDBert
05-01-2004 06:53:04
Theres O-rings on the shaft where the throw out bearing/ clucth engagement is that go bad. You have to split the tractor and remove a "stub" shaft, theres a o-ring on the inside and one on the out side.
mike
05-02-2004 04:28:49
 Re: Re: 4320 oil leak out clutch insp.cover in reply to JDBert, 05-01-2004 06:53:04
are these orings between the engine and clutch housing or clutch housing and trans the only orings i know of are the two behind the pto piston housing and the orings inthe housing around the pistons
