3010 with a zenith carb
Tim D
04-30-2004 20:47:01
I have a 1963 model 3010 with a zenith carb on it. I want to eliminate the fuel shutoff and go back to the manual adjustment like the older carbs had on them. I went to john deere and they told me the manual adjuster was obsolete and they couldn't get it anymore. I have also heard there is an automotive part that will do the same thing.
Any help would be appreciated....those solenoids are expensive and don't work very well.
chris
05-01-2004 17:46:57
 Re: 3010 with a zenith carb in reply to Tim D, 04-30-2004 20:47:01
This might not be the answer you want but, when I worked for jd I worked on a tractor that the solenoid was shorting out causing the tractor to shut off. I unplugged the wire to the solenoid and removed the needle from the solenoid and reinstalled and never heard from the guy again. This was a few years ago and I ran the tractor for 20 minutes running the bushhog and everything was working. And I might have a new solenoid if you have the part number and $15-20. chris
Tim D
05-01-2004 15:46:13
Anyone?
