Is it salvagable???
rob
04-30-2004 18:50:41
I really need some honest opinions here. I was planting corn with my 4020 (64 syncro) and all of the sudden my oil pressure light came on, blue smoke poured out of the oil cooler? and it started a solid knocking noise. I checked the oil before and after and it is still in range. I shut her down instantly and towed her to the edge. Now I am just sick, I had just got her painted and new tires all around, and she was to go in Sunday to have the pto fixed and the clutch redone while she was split. Is it worth the extra money for the motor work and all the clutches redone or should I sell her for scrap and buy another one, I know what I want to do but I am biased, honest opinons please. Thank you. By the way it sure looked good pulling that "new" 7000 6 row planter.
jdemaris
05-01-2004 17:42:41
 Re: Is it salvagable??? in reply to rob, 04-30-2004 18:50:41
I can't imagine scrapping a 4020 for want of maybe $2000 in parts to fix it. Don't know about your labor bill if you're paying to have it all done, including the two clutches. Now, if someone was to offer you $3000 or $4000 for it as is, and you bought another good 4020 for $8000, then maybe it would make more sense. If it was mine, fixing it would be a no-brainer.
Paul
05-01-2004 06:27:10
a freind who works with trucks told me once any doubt at all pull the pan and put bearings in it dont look at them replace them. I know thats a little to late in your case but maybe a good reminder for others in similar shoes.
the engines on 4010 and 4020 were not built in time of 10,000 plus hour engine lifetimes (oil quality) so to have one fail at 8500 no surprise. now for your question just shut your eyes and fix then you will know what you got.buying another one that probably needs work wont solve your delima> Paul
Wayne
05-01-2004 05:26:07
That oil cooler tube you mention is NOT the oil cooler tube.
It is the breather tube coming out of the valve cover.
You better go get you something with a handle in it , like maybe a hoe!!!!! !!!!!
Russ
05-01-2004 04:56:58
HOT DEERE! YOU MUST HAVE THIS RIG ALREADY PAID OFF. IF YOU CAN STILL PUT FOOD ON THE TABLE ITS TIME TO START FINDING OUT WHERE THE HOT SPOT IS.
PULL DOWN THE OIL PAN AND REMOVE BIG END CONROD CAPS. INSPECT FOR THE LUBRICATION FAILURE.
8400 HRS IS A GOOD TIME TO COMMIT TO AN ENGINE OVERHAUL. THERE IS A GOOD DEAL OF EXPERIENCE HERE AND ELSEWHERE ON THE INTERNET.
THE DECISIONS HERE ARE ALL YOURS. TIME, MONEY AND REPAIR CHALLENGE.
Russ
05-01-2004 05:12:51
 Re: Re: Is it salvagable??? in reply to Russ, 05-01-2004 04:56:58
1964 JD 4020 SYNCHRO; 6 CYL, 404 CID DSL, 8F-2R, 95 HP, 8585 LBS, LO 4700, MID 6990, HI 8810 WHETHER A HEAT, LUBE FAILURE OR SOMETHING ELSE ITS GOOD TO KNOW WHAT IT MAY BE WORTH ONCE REPAIRED BACK UP TO A DECENT LEVEL.
Bpb
05-01-2004 04:43:15
Yes it is too good of a tractor to salvage. You have enough in it now you may as well keep going. I'm Not a John Deere man, but my brother is. I have an old Alls Chalmers with more in it than it is worth, but I know what I have and I'm satisfied I did the right thing.
Good luck
Bob
04-30-2004 19:54:32
I'm afraid I'm not quite following you when you state "blue smoke poured out of the oil cooler".
The oil cooler on a 4020 does not commonly pour out blue smoke, so I must be missing something!
Also, you state "all" the clutches have been rebuilt. Are you just referring to the foot clutch and the PTO clutch, or do you, in fact, have a powershift?
rob
05-01-2004 02:13:46
 Re: Re: Is it salvagable??? in reply to Bob, 04-30-2004 19:54:32
To help clear things up, The pto clutch has been out for a time and the guy was coming to get it Sunday to split it and replace the pto clutch, also we decided to have the foot clutch reworked while it is split. Also the motor has 8400 hrs. and has never been touched so hourwise it was needing the OH, but now do you sink 5-6,000 for work into it or sale it for parts and buy another one. *the blue smoke poured out from the oil cooler tube underneath the tractor* Hope this helps clear things up,so you can help me make an educated decision. Thanks
leon
05-01-2004 05:23:54
 Re: Re: Re: Is it salvagable??? in reply to rob, 05-01-2004 02:13:46
There is no oil cooler tube beneath the tractor that blue smoke can pour out of. Perhaps was it the crankcase vent tube that the smoke came out of? If so, this is probably a strong indication of lack of lubrication. This could have resulted damage to main bearings, rod bearings and possible piston and cylinder scoring.
Steve ii JD 4000
04-30-2004 20:04:59
bob, what I am thinking, blue smoke, I guess the clutch is going out, that has happen to my 4000, or may have a broken oil line some where (oil light come on) oil cooler is on side of engine.. and he say a solid knocking noise, it sounds like a rod got throw out or from clutch?
by the way he say a 64 syncro..
steve
Steve ii JD 4000
04-30-2004 19:51:49
dont sell it to scrap.... you wont get alot from scrap.. only thing to do is find out what is wrong.
I have a 71 4000 JD it needs engine work and I am planing on doing repair my self.
steve
